Presto K8 / K10
Presto K8 / K10
Hi guys , im planning to pass my K to diamond/PVC , some troll can (please) let me know if its reasonable ? The non centered path that the cutting arm do ... it have some issue that i need to take in care with diamonds ?
Thanks in advance
Mani
Thanks in advance
Mani
- monkey1553
Mani,
I'm not too familiar with the K model but how is the mech that lowers the cutter/stylus to the platter on your model? I know you will want to take great care lowering the diamond so that it doesn't chip or get damaged. I'm not sure how the different cutter path setup will effect things maybe others can chime in. Has everything worked fine in the past when you used sapphire?
-Michael
-Michael
Eyy ... thanx for the fast answer man , I don't know if pretty good , I only had material to test a few grooves ( thanks to Nickou for their remnants ) , seems ok , a bit noisy , but this is stylus related problem , the stylus source its unknow , really most of what I did its embossing with stylus tip , that works great , tilting Peter King style the results was be amazing.
The suspension its the spring one , but dont worry about that , I own the VR and I think I know the way that the stylus must attack the surface , really dont worry me , even the suspension would be modded more in dashpot style , that its in the plan too , as the heat , or the filtering section , the claim is make a very portable system.
Any infos is appreciated guys , thanks.
Mani
Mani
http://www.ebay.com/itm/Russco-Cue-Master-QRK-3-Speed-50-Hz-Motor-Capstan-/300638898472?pt=Vintage_Electronics_R2 , I bought that for the babe , someone try it on a K in a country with 50 hz mains ?
Project evolution gonna be posted here.
Any suggestions , tips , and neurons will be appreciated.
Thanks guys and gals , Mani.
- petermontg
Are you trying to use that 50hz capstan on a 60hz TT. you could check with sket at russco themselves. hes pretty responsive.maniman wrote:http://www.ebay.com/itm/Russco-Cue-Master-QRK-3-Speed-50-Hz-Motor-Capstan-/300638898472?pt=Vintage_Electronics_R2 , I bought that for the babe , someone try it on a K in a country with 50 hz mains ?
http://www.russcoturntables.com/
Peter Montgomery
+353(0)894926271
+353(0)894926271
Hi Peter thanks , beginner error , I was very excited with this , and bought at ebay without thinking a lot about .... But , Im gonna take in care when start with my LD Lathe restoration ( that one at my avatar ) , the motor of the LD was be chaged by a Bodine , coz of that , really other one capstan will be needed. (or finally get a motor controller)
You think that works ? ( use the capstan to resolve 50 / 60 mains issue )
And as experienced cutter like you Peter .... what you think about use a diamond with the K10 recording arm ? with the non linear path that describes...
Thanks.
Thanks.
- petermontg
Am no experience cutter, only cutting about a year in marchmaniman wrote:Hi Peter thanks , beginner error , I was very excited with this , and bought at ebay without thinking a lot about .... But , Im gonna take in care when start with my LD Lathe restoration ( that one at my avatar ) , the motor of the LD was be chaged by a Bodine , coz of that , really other one capstan will be needed. (or finally get a motor controller)
Thanks.
No the only way to resolve a 50/60hz is to change out the motor. you can get little power converters in any DIY store (30E).
Remember though you have to use a 60hz on a stobe disk and 60hz strobe to set the table, a Tachometer(not for measuring Tachyons ) off ebay will only set you back about 20E and less of a pain. I have a 60hz collins 200s that i use for cutting.
Edit: i have to slow down the source material 16.66% to offset the freq difference between 50/60hz.
http://www.ebay.ie/itm/180771880093?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
With regards to a diamond am not sure how it will work with a non linear path, the pressure on the needle will be coming from different angle at different stages of cutting.
Have you tried with a saffire yet?? It could be best to try with one first and see does any problems arise.
Another Edit: I have been thinking that if the cutter was orginialy built to handle a saffire you shouldn't have much problems with diamond,if any.
Peter Montgomery
+353(0)894926271
+353(0)894926271
