Lacquer Used to Coat Master Discs
- ExquisitePastry
Hi all,
I currently work as a research assistant where my project is to repurpose the vinyl grooves when cut to use as microfluidic devices (basically really small plumbing to flow small amounts of fluid across a surface). To my understanding, vinyl masters are usually made of some soft metal and then coated with nitrocellulose lacquer. Is there a way for me to get my hands on the specific lacquer that is used for this process? I believe some guitars are finished in this type of lacquer but I am not too sure if it is the same formulation. Also, does anyone know the process of application & drying the lacquer that is used on the disc?
Athough I am definitely not passionate of vinyl cutting, I do think it is really cool that such a community exists here
Re: Lacquer Used to Coat Master Discs
Unfortunately that's a tightly held secret. If we knew the formula, there would be more than just two manufacturers in the world.
Two of our members here have four different formulas between them. A search might help. The lacquer is applied to the polished alunium substrate via a curtain coater. I've seen the process but don't recall how they're dried. You can see the process on a YouTube video called, "How It's Made - Vinyl Records". Good luck.
- ExquisitePastry
Thanks for the response guys, I'll definitely check out the formulations by the board members in here.
I was very surprised how hard was to obtain information out there about the fabrication process along with the reasons one why certain methods are used over others. I have an easier time finding data in my research interests, which is a fairly niche field for my study, than information on vinyl mastering. I guess I know why now, thanks again guys!
- fredbissnette
a proper wizard never reveals all
It never ceases to amaze me that what is now ancient technology - that wasn't even patentable in the first place - is "tightly guarded." Even if someone has "the formula" - making a viable recording disc, much less something the quality of a master, would be impossible without all the supporting equipment necessary to the process. Surface prep, the coating process, the drying process, center hole punching, inspection, testing, QC, R&D - a pretty overwhelming process; the formula is just a drop in the bucket, for lack of a better expression.
I can not help thinking there is a certain amount of “Smoke & Mirrors” with the process
Lets just say you better like thinking out of the box,,,,,,,,,& then out of that box,,,,,,,,,,,& again out of that box,,,,,,& then out of that box....
I hope you get the idea.
