VMS 70 vacuum hose max length?
I currently have the vacuum in another room to reduce noise. I'm moving the lathe to a different spot and I'll need to extend the distance from the vacuum box to the lathe from about 4' to 8' or more. Does anyone have the vacuum box in a remote location? Anything I should be aware of?
-Kevin
-Kevin
Re: VMS 70 vacuum hose max length?
I had a vacuum cleaner in another room with a 6 or 7 metre swimming pool vacuum hose.
Hose diameter about 5cm.
It ran like that for years.
Try it and see.
Try it and see.
- dietrich10
My vacuum is located in a hallway and I have the hose going through the wall. The length is much longer than needed but does not effect the results.
cutting lacquers-vms70 system
- Greg Reierson
I'm running 2" hose about 20'. 100's of feet would still be fine. There's very little airflow so distance barely matters if the system is air-tight. And whatever difference there is can be compensated for with the variac.
- jtransition
I have my vacuum,sitting under the swarf jar, Inside a muffler box similar to the ones originally supplied with the lathe,Whilst it is not silent the noise is never a problem.
- Greg Reierson
Silence is golden. Move it out of the room and you'll never go back.
OK thanks, I figured it wasn't a factor, just wanted to check.
-Kevin
-Kevin
- leemichael
I use one of these bad boys on a long hose:
https://www.ebay.com/itm/New-102237-A002-Gardner-Denver-Elmo-Rietschle-VLT-40-2hp-Vacuum-Pump-/164013135211
Still has enough suction to suck your face off!
