digitised standard test records
madirishman
Post: # 51982Unread post madirishman
Tue Jan 01, 2019 11:41 am
Greetings, site search revealed NO .wav or .flac files of any standard test record with a constant amplitude sweep or a squarewave. Surprising. Anyone have one to put on dropbox? cheers, Madirishman (old buddy of Ricker's)
jjgolden
Re: digitised standard test records
Post: # 51985Unread post jjgolden
Tue Jan 01, 2019 1:32 pm
Hello,
What's the intended use of a digital copy of a test record?
madirishman
Post: # 51987Unread post madirishman
Wed Jan 02, 2019 6:17 am
I want to examine aspects of the data for scientific reasons, not commercial usage.
Post: # 51989Unread post markrob
Wed Jan 02, 2019 9:57 am
I can't imagine what information you would be able to get from a digital copy of a playback from a test record. At a bare minimum, you would need to know the conditions under which that the capture was done (e.g. pickup output vs. velocity, preamp gain, system frequency response, distortion levels) to name a few. Can you be more specific what you are trying to do here?
NAB did make a test CD series. Maybe that is what you need:
http://www.nabstore.com/ProductDetails.asp?ProductCode=CP400
https://www.nabstore.com/NAB_Broadcast_Audio_Test_CD_Vol_1_p/cp500.htm
madirishman
Post: # 51991Unread post madirishman
Wed Jan 02, 2019 1:23 pm
Thanks for your interest, Mark.
Sorry, for reasons of IP, I do not wish to be more specific except to register my disagreement with your statement on the requirement of knowing minimum conditions.
Post: # 51998Unread post markrob
Wed Jan 02, 2019 4:59 pm
No problem. Good luck with your project. Have you considered picking up a copy of a test record on eBay and doing the transfer yourself? They come up pretty often in various conditions. Is there a specific test record you are looking for (e.g. one of the CBS STR series)?
