Westrex 3DIIA on Neumann suspension box
pandapolar
Post: # 37993Unread post pandapolar
Tue Oct 20, 2015 11:45 pm
Just need to ask if anyone has had experience with using a Westrex 3DIIA head on a suspension box?? my worry being the cutter lift button .. the spring isnt strong enough to lift the westrex... has anyone beefed up that spring before?? also is the advance ball on the head needed??
thanks
Sillitoe
Re: Westrex 3DIIA on Neumann suspension box
Post: # 37995Unread post Sillitoe
Wed Oct 21, 2015 12:29 am
Hi Pandapolar,
Joe Malone told me about your setup and I saw pics on your facebook page. It looks great, congratulations!
Were you able to get the head far enough back so the stylus lines up with the spindle?
I can't tell if you've already achieved that or not from the pic...
James
pandapolar
Post: # 37996Unread post pandapolar
Wed Oct 21, 2015 12:57 am
as it is its 10mm in front of the spindle .. however we are working on a bracket to get the head further back :)
Alex
Post: # 37999Unread post mossboss
Wed Oct 21, 2015 4:17 am
Inside the suspension box there is a spring as you well know.
If you look at it carefully you will see it has adjustment
The section that attaches the stud with the thread it has some holes
Thats where the nut to take up the weight goes where we adjust at the back
In this it has a section In which you can move the hook on the spring
Move it so as to balance the weight.
It should be no issue. Its been done before
It has nothing to do with the lever as when balanced it will not exert any more pressure than normal
At any rate the lever has its own lifting system
Best
pandapolar
Post: # 38013Unread post pandapolar
Thu Oct 22, 2015 6:45 pm
Beautiful... thanks chris :)
Post: # 38023Unread post Aussie0zborn
Thu Oct 22, 2015 9:24 pm
One of my Neumann lathes cane with a Westrex 3DII cutter-head so it is do-able. Follow the advice here and you will be good to go.
When this head is used with a Neumann lathe, the advance ball is unnecessary. Turn the knurled knob to raise it above the lacquer and leave it there.
The advance ball scuffs the lacquer but if set properly, the groove is cut into the scuff mark. If not set properly, you will see a scuff Mark in the land. Seeing as the Neumann suspension box will adjust the depth, you don't need the advance ball in this set up. Happy cutting. !!
pandapolar
Post: # 38025Unread post pandapolar
Thu Oct 22, 2015 9:37 pm
awesome thanks... what did you do to counter the issue with the head sitting too far forward?? we are think a bracket to move the suspension box back until the head lines up with the spindle..
pandapolar
Post: # 38026Unread post pandapolar
Thu Oct 22, 2015 9:40 pm
this is the setup so far :)
we are going to get a pitch13 from flo to counter the fixed pitch issue... so far so good :)
Post: # 38029Unread post mossboss
Fri Oct 23, 2015 4:38 am
pandapolar wrote:awesome thanks... what did you do to counter the issue with the head sitting too far forward?? we are think a bracket to move the suspension box back until the head lines up with the spindle..
On The four bolts which hold the up and down slide on the neck one can have a 10 mm thick metal plate with a set of holes to take the sus box with couner sunk screws and another set of four to mount it further back
This will work however if memory serves me well there was a standard stub for the Neumann, you replace the existing one. Maybe someone here has one
Place a wanted in the classifieds
Best
Post: # 38030Unread post Aussie0zborn
Fri Oct 23, 2015 4:45 am
I received the lathe already set up for the Westrex head. I never noticed how it was done as I put it in the shed once I got the VMS62 which also went into the shed when I got the VMS70 so I never made a visual comparison. That lathe is in Korea now so not possible to check. I would think you could make a plate for the required offset and mount it between the overhead arm and the rack and pinion.
The Pitch 13 system sounds like a good idea. If you consider Doug Sax used this or a similar model you should be able to cut like a pro once the Pitch system is installed.
gold
Post: # 38047Unread post gold
Sat Oct 24, 2015 2:42 pm
Is the solenoid powerful enough to do depth control well?
Post: # 38049Unread post mossboss
Sun Oct 25, 2015 4:41 am
Since the weight is taken by the spring there is no more or less weight to deal with
Best
gold
Post: # 38056Unread post gold
Sun Oct 25, 2015 12:07 pm
mossboss wrote:Since the weight is taken by the spring there is no more or less weight to deal with
Best
No more weight is a static position. I am asking if it can be controlled dynamically by the solenoid.
Post: # 38078Unread post mossboss
Mon Oct 26, 2015 5:35 am
Yes
pandapolar
Post: # 38302Unread post pandapolar
Tue Nov 03, 2015 9:08 pm
bracket done and ready to go ;)
pellegrino707
Post: # 38494Unread post pellegrino707
Fri Nov 13, 2015 12:25 pm
Your lathe looks anazing, congratulations!
Can i ask you which model of neumann it is?
Marco
Post: # 38502Unread post mossboss
Sat Nov 14, 2015 4:59 am
Nice very much ala Scully
Best
pandapolar
Post: # 38523Unread post pandapolar
Sun Nov 15, 2015 4:49 pm
pellegrino707 wrote:Your lathe looks anazing, congratulations!
Marco
It a Neumann AM31a :)
JSA
Post: # 38557Unread post JSA
Wed Nov 18, 2015 8:32 am
What kind of adapter is needed to mount westrex on neumann suspension box? Been thinking about 3d and 2b lately
Thanks
petermontg
Post: # 38558Unread post petermontg
Wed Nov 18, 2015 9:16 am
Male collet with correct angle...
Am sure some of the lads here could make you one.
Plenty of hobbyist and pro machinist hanging around.
Peter Montgomery
+353(0)894926271
