Humidifier in cutting room?
concretecowboy71
Post: # 28771Unread post concretecowboy71
Tue Jan 28, 2014 1:59 pm
With the temp here in Cleveland hovering around 0 degrees F, the heat has been running constantly and although I have humidifiers in several rooms, two days ago I started having massive chip pickup problems. I went through all of the usual troubleshooting and had no improvement at all. As a last ditch effort, I brought a small humidifier into the room and ran it for a while. The first record I cut had excellent chip pick up...seems like the static electricity was causing the chip to stick to the lacquer.
Anybody else have this experience?
Re: Humidifier in cutting room?
Post: # 28772Unread post opcode66
Tue Jan 28, 2014 4:54 pm
Doesn't surprise me.
dietrich10
Post: # 28774Unread post dietrich10
Tue Jan 28, 2014 7:43 pm
My current cutting room and last both use forced hot air heat via gas. I always run the humidifiers partial every day especially when the lacquer days. If not I get chip issues(not to mental static not good for the gear!)
cutting lacquers-vms70 system
Bob Weston
Post: # 28816Unread post Bob Weston
Fri Jan 31, 2014 1:41 pm
We run a humidifier in the lathe room pretty much all winter.
-bw
chenry57
Post: # 28874Unread post chenry57
Sun Feb 09, 2014 1:08 am
I had a similar issue, even though we aren't having Cleveland weather in Nashville, it has been sub-20° here. Ended up running the AC for a bit (dedicated unit in my room) and it cleared up the issue. I fought the chip for awhile. I even changed the stylus thinking that it had something to do with it before thinking about static.
Post: # 28876Unread post markrob
Sun Feb 09, 2014 9:20 am
chenry57 wrote:I had a similar issue, even though we aren't having Cleveland weather in Nashville, it has been sub-20° here. Ended up running the AC for a bit (dedicated unit in my room) and it cleared up the issue. I fought the chip for awhile. I even changed the stylus thinking that it had something to do with it before thinking about static.
That seems counterintuitive. An AC normally removes moisture from the air. I would think that would make it more static prone. In my house, I run a humidifier in the winter months to increase the relative humidity. That helps keep the static electricity level down. If the outside temperature is 20F, I rather doubt running and AC would even do anything as it needs to see a temperature differential (outside hotter than inside) to work.
chenry57
Post: # 28899Unread post chenry57
Tue Feb 11, 2014 2:30 pm
The cold air being pumped in from outside has more moisture than the dry air coming from the heater. And since I'm not having chip issues anymore, I'm going to stick with it.
dietrich10
Post: # 28908Unread post dietrich10
Wed Feb 12, 2014 11:37 am
First winter chip issues today but not sure if its the new box of Apollos. the last box was Transco and no issues.
JSA
Post: # 28927Unread post JSA
Fri Feb 14, 2014 4:40 am
I use bucket with water, recommended by master cutting engineer S. Davies
Jukka
Timmion Cutting Lab. Helsinki/Finland
Neumann VMS70 with very Funky CBS Disc Computer system /SAL74/SP79/SX74
krystoph
Post: # 29250Unread post krystoph
Wed Mar 12, 2014 8:00 pm
Chalk me up as another who has to use a humidifier in the cutting room or I get chip pickup problems. Funny, I didn't need it in August. Haha.
hawkweed
Post: # 29304Unread post hawkweed
Mon Mar 17, 2014 8:21 pm
I cut on makrolon and have had the same issues. Humidifier is a must have for cutter room
Hawkweed Record Project
http://hawkweedrecords.yolasite.com/
