does anyone cover their Neumann or other lathe at night etc?
dietrich10
Post: # 19099Unread post dietrich10
Fri Apr 06, 2012 6:20 pm
Curious as I've never seen this done
keeps less dust?
cutting lacquers-vms70 system
Post: # 19100Unread post opcode66
Fri Apr 06, 2012 6:54 pm
I put a piece of foldeed paper over the oiled track to keep dust from settling on it.
audadvnc
Post: # 19119Unread post audadvnc
Sun Apr 08, 2012 5:24 pm
I'm setting up our lathe in a somewhat dusty (old industrial warehouse) area and am planning to cover it nightly with plastic, canvas or whatnot. My main concern is inadvertently damaging something on the record head if the needle catches on some fold on the cover.
concretecowboy71
Post: # 19123Unread post concretecowboy71
Mon Apr 09, 2012 11:03 am
You could probably use a cover sold for motorcycle storage.
Seems like about the right size. They usually have some elastic around the bottom which could help keep junk from blowing up and under also.
You can always take the cutterhead off at night if you are worried about snagging it on the cover.
fraggle
Post: # 19125Unread post fraggle
Mon Apr 09, 2012 12:00 pm
taking the head off?
is that really necessary? sounds like a lot of work adjusting and stuff every day.
concretecowboy71
Post: # 19129Unread post concretecowboy71
Mon Apr 09, 2012 1:34 pm
Well, he was concerned about it and offered an easy solution.
You are correct about it being extra work, I would not do it myself but if the conditions are dusty, it might be a good idea anyway.
I can't really see on a Neumann that process taking more than 10 minutes on any given day.
gold
Post: # 19131Unread post gold
Mon Apr 09, 2012 1:39 pm
I use an uncoated 14" lacquer blank to cover the turntable. I asked Apollo for the aluminum blank.
Bonati
Post: # 19146Unread post Bonati
Mon Apr 09, 2012 9:50 pm
I use an old Army band 16" transcription record that I got at a flea market. Covers the whole platter.
gengy
Post: # 19174Unread post gengy
Thu Apr 12, 2012 10:51 am
I use only the paper that we find in the lacquer box for covering the turntable of the vms 80.
Alessandro Di Guglielmo
Mastering and Disk Cutting
powerstrip
Post: # 21634Unread post powerstrip
Mon Oct 29, 2012 8:58 pm
Bonati wrote:I use an old Army band 16" transcription record that I got at a flea market. Covers the whole platter.
Genius...
I do the same with a 16", I have about 20 of them, useless, except for this dust-cover technique, which, unfortunately, were stored improperly over the years, and 'curdled' as I call it. A separate box of 25 red- label 12" 's were in fine condition, though!
