Helium
- jtransition
Helium
Who is using what?
I am using medical grade 99.997 % pure as recomended 13years ago ,with no problems but i have noticed a few people using baloon gas which varies in purity,
Has anyone used both for a considerable time?
Thanks
Jason
Thanks
Jason
- concretecowboy71
I'm also following the manual's advice. I'm renting the smallest tank available - it's probably the same tank that the company rents to moms & clowns for balloons. Seems to be working fine. Maybe Kevin Gray could chime in here if he's had any experience with various types of helium and how they affect performance (if at all).
Josh Bonati
www.bonatimastering.com
Hellium
Well lts be realistic guys It is only used for cooling down the head so purity matters zilts Lowets cost its the way to go
Neumann also suggests to be left onat all times but that was back in the days where it may have been cheap not nw days
By the way you need a proper hellium guage as the stuff would leak out through the damn threads as it is the second smallest atom known hydrogen being the smallest
We turn it off after a cut always
Thanks Chris - good to know. I also shut the tanks off at the end of the day.
Josh Bonati
- dietrich10
hmmm. let the helium run through a glas (gold is even better) pyramide with a germanium (99.98) cube of exactly (sqrt(5)+1)/2 side lengt inside.
this gives you another 2 extra dBs in the highs. and the sound becomes incredible transparent.
also i can swing the best place for your lathe in your studio...at least another 1-2 dBs.
use ballon gas. dont forget to turn off after the cut. a solenoid controlled by cutter up signal. makes your bottle last for almost ever...
and the coils will thank you...
Re: Hellium
Hi Chris,mossboss wrote:Hey Flo
Is this fact? Sounds like resharpenning your razor blades in a paper pyramid of some years ago Or preserving dead cat's in them as well
Some photos please if poss
Thanks Flo
sorry for off topic, but do you know that the case with fast resharpening of razor blades is patented by a Czech micro-wave engineer Karel Drbal?
http://silesia.wz.cz/drbaleng.htm
more auto-translated info here:
http://translate.google.cz/translate?js=y&prev=_t&hl=cs&ie=UTF-8&layout=1&eotf=1&u=http%3A%2F%2Fwww.oranzovestranky.cz%2Fview.php%3Fcisloclanku%3D2005120205&sl=cs&tl=en
Maybe Flo also can use some kind of "esoteric power"?
Jiri Zita
Premastering manager
GZ Vinyl / GZ Media Lodenice
Czech Republic
Czech Republic
Hi Flo - interesting things here. Could you maybe explain in more detail?
Do you have any pictures of this setup? What's a gold pyramid??flozki wrote:hmmm. let the helium run through a glas (gold is even better) pyramide with a germanium (99.98) cube of exactly (sqrt(5)+1)/2 side lengt inside. this gives you another 2 extra dBs in the highs. and the sound becomes incredible transparent.
What do you mean here? Lathe placement = higher cutting levels?also i can swing the best place for your lathe in your studio...at least another 1-2 dBs.
So...this system shuts off the helium valve when the cutterhead is lifted after cutting? Does the flow meter/helium turn "on" when the cutterhead is lowered? Did you design this?use ballon gas. dont forget to turn off after the cut. a solenoid controlled by cutter up signal. makes your bottle last for almost ever...
Josh Bonati
- jtransition
LOLflozki wrote:hmmm. let the helium run through a glas (gold is even better) pyramide with a germanium (99.98) cube of exactly (sqrt(5)+1)/2 side lengt inside.
I like the solenoid ideause ballon gas. dont forget to turn off after the cut. a solenoid controlled by cutter up signal. makes your bottle last for almost ever...
