Mid-range budget cutting chain. What processors?
sameal
Post: # 40198Unread post sameal
Tue Feb 02, 2016 10:27 am
Im curious what processing everyone is running before the lathe. Im going to have to start thinking in these terms pretty soon, and i have some things hanging around already, so itd be a good idea for me to start looking at what works and what doesnt, in a sane price range to start.
So whats everyone running?
gold
Re: Mid-range budget cutting chain. What processors?
Post: # 40200Unread post gold
Tue Feb 02, 2016 6:48 pm
Are you looking for basic cutting processors like an EE, HPF/LPF and HF limiter? Or are you looking for "mastering" processors like EQ's and compressors?
sameal
Post: # 40203Unread post sameal
Tue Feb 02, 2016 8:14 pm
Lets do both!
Im hoping to be able to cut from any source, but id venture to guess 9 times out of ten my source would be from a computer.
A tape path is in the works, but not solid yet.
gold
Post: # 40204Unread post gold
Tue Feb 02, 2016 10:03 pm
i know many DAW's have some sort of Stereo Enhancement tool. The one in Sequoia is multiband so you can use it as an EE.
The best plug in EQ I've run across is the DMG Equilibrium. You could set that up as an EE by putting a filter on the side channel. It also has stereo HPF/LPF and lots of regular EQ.
The DMG Essence de esser is getting great reviews from people i know and trust although I haven't used it. It will probably work well as a HF limiter.
The only software compressors I use are the Flux Alchemist multiband, which is expensive and the Sonoris mastering compressor. Software compressors are notoriously bad sounding. Other than the Alchemist I can't really recommend one. I use the Sonoris for non heavy lifting tasks occasionally.
gold
Post: # 40205Unread post gold
Tue Feb 02, 2016 10:09 pm
If you don't need preview channels then you could use two channel analog processors as well. A BSS DPR902 would be my choice for high frequency limiter if a Maselec wasn't in the cards. There are a zillion EQ and compressor choices. I'd look for an EQ with an HPF/LPF
I have some Neumann EE66 cards if you want an analog EE. There is also Wayne Kirkwood's Stereo Widener board which can be set up as an EE.
Sillitoe
Post: # 40207Unread post Sillitoe
Tue Feb 02, 2016 11:24 pm
The DMG eq looks amazing, cheers Gold!
Great review here http://squarecad.net/ArchivePages/squarecad64-dmgeq.html
I really enjoyed your interview too!
Post: # 40215Unread post tragwag
Wed Feb 03, 2016 9:49 am
I've heard good things about the Brainworx BX digital V2,
it's a software mastering EQ with heavy M/S capabilities, including de-ess and EE
seems very useful for example, de-essing cymbals on the sides and keeping center vocals untouched.
sameal
Post: # 40329Unread post sameal
Sat Feb 06, 2016 6:40 pm
Definitely getting into a different realm of processors then i have on hand i feel.
Optimally i think both an analog and digital path is what im after.
sakuszi
Post: # 40347Unread post sakuszi
Sun Feb 07, 2016 12:53 am
Hi, I need a schematic diagram of the limiter modulation vertical , I pay lot of money
audiocarver
Post: # 40367Unread post audiocarver
Sun Feb 07, 2016 8:33 am
I'm doing everything OTB, but that's just how I am because I like turning knobs, pushing buttons and seeing real blinking lights on a console! :lol:
But to interface to the digital world, I am looking for some decent AD/DA converters. I was looking at the Lavry black series. Anyone else use them?
flozki
Post: # 40382Unread post flozki
Sun Feb 07, 2016 12:29 pm
if you go the cash.around 5k depending on options. go for this one
full analog 4 channel mastering processor.
http://www.flokason.ch/fs_flokason_gear.html
RDL. 24 step ELMA -5.5 to +5.5 dB
Elliptical EQ
LOW CUT
HIGH CUT
AUX
CUTTER OFF
REMOTE for Pitch13
check
sakuszi
Post: # 40397Unread post sakuszi
Sun Feb 07, 2016 5:09 pm
Hello . Mr. Lord Flozki . Price in 5000 is such money? This price is a schematic diagram ? In what currency ?
sakuszi
Post: # 40406Unread post sakuszi
Sun Feb 07, 2016 6:28 pm
Mr Flozki .I have one question, do you have circuits afterburner, "nitrous oxide" in German machines is mounted BSB74, what will be the price for 2 pieces, possibly to test the loan, pay a deposit of modules BSB74 ?
sakuszi
Post: # 40536Unread post sakuszi
Wed Feb 10, 2016 5:41 pm
Mr Flozki! You do not answer e mail !. Thank you for your cooperation. I have a schematic for $ 5. Goodbye ! :mrgreen:
