Newbilt extruder - changing colours waste
filiperibeiro
Post: # 61732Unread post filiperibeiro
Mon Nov 14, 2022 9:41 am
Hi everyone!
We work with a newbilt extruder. We always have the same problem whenever we change colors.
We start with the manual purge to start getting the new color completely clean, but the first 40 records or so always keep a little bit of the previous color.
Is there any way we can not have so many waste on the first initial records?
Radardoug
Re: Newbilt extruder - changing colours waste
Post: # 61744Unread post Radardoug
Tue Nov 15, 2022 2:20 pm
Clearly if you have residue from the old color, you are missing something in your cleaning process.
untitledthe
Post: # 61753Unread post untitledthe
Wed Nov 16, 2022 11:12 am
In case you arent using it yet try pvc cleaner granulate to pruge the previous color. Ask you granulate supplier.
filiperibeiro
Post: # 61765Unread post filiperibeiro
Fri Nov 18, 2022 3:44 pm
Thank you!
llary
Post: # 61886Unread post llary
Mon Dec 05, 2022 7:44 am
PVC cleaner in my experience is more expensive than just running clear compound through the barrel. Minimizing waste is more of an operational thing than technical - plan your jobs carefully to group similar colors, only purge material if and when absolutely necessary. Work from lighter to darker colors then back again.
