Cracked Labels
jlbfalcao
Cracked Labels
Post: # 61260Unread post jlbfalcao
Thu Aug 11, 2022 4:34 pm
Has anyone ever had a problem like this. We left the labels at 140 degrees for about 2h and tested with different labels.
misjah
Re: Label issues
Post: # 61263Unread post misjah
Fri Aug 12, 2022 2:38 am
stamper sanded well enough under label?
untitledthe
Re: Label issues
Post: # 61266Unread post untitledthe
Fri Aug 12, 2022 4:32 am
Try for longer time in the oven
jlbfalcao
Re: Label issues
Post: # 61273Unread post jlbfalcao
Sun Aug 14, 2022 6:18 am
We never tried it before, but it worked! Thanks.
But I have some questions:
1) What's the best way to do that without screwing up the stamper?
2) When (and why) is this process required for some stampers?
I appreciate any help you can provide.
misjah
Re: Label issues
Post: # 61274Unread post misjah
Sun Aug 14, 2022 8:02 am
It’s not done on the stamper its normally done on the lacquer/dmm before making the stamper.
Re: Label issues
Post: # 61283Unread post Aussie0zborn
Mon Aug 15, 2022 12:33 am
The label area on the master disc (either lacquer or DMM) needs to be roughened so that label has something to adhere to and not crack. Also, the PVC needs to be hot enough/soft enough to prevent cracking of labels. Pressing speed also plays a role.
Drying is only to remove moisture from the paper - its not to prevent cracking so don't follow the advice above and bake them longer. (This would increase the chance of labels cracking).
filiperibeiro
Re: Cracked Labels
Post: # 61299Unread post filiperibeiro
Thu Aug 18, 2022 10:28 am
still on this subject of labels: has anyone ever encountered the following problem: the glue of the labels smears to the side and the stamper gets a stain like this.
Re: Cracked Labels
Post: # 61301Unread post Aussie0zborn
Thu Aug 18, 2022 6:20 pm
Labels don’t use glue. The heat and pressure allows the labels to adhere to the record. This is something else.
llary
Re: Cracked Labels
Post: # 61302Unread post llary
Thu Aug 18, 2022 10:10 pm
Manual or automatic press? If manual are you leaving hot pucks sitting around before pressing?
llary
Re: Label issues
Post: # 61303Unread post llary
Thu Aug 18, 2022 10:11 pm
That will make the problem worse. Need to throw those baked labels out and start again baking very carefully checking every 15 mins
llary
Re: Label issues
Post: # 61304Unread post llary
Thu Aug 18, 2022 10:13 pm
It's no problem to sand directly on the label area of a stamper, we use 100mm sanding discs and a turntable to do this more efficiently
llary
Re: Label issues
Post: # 61305Unread post llary
Fri Aug 19, 2022 1:09 am
Sanding the label area is done to reduce the contact surface area between mould and stamper so there is less heat transferred to the label.
The opposite is true for the back of the groove area which needs a high polish for excellent contact and efficient heat transfer.
filiperibeiro
Re: Cracked Labels
Post: # 61307Unread post filiperibeiro
Fri Aug 19, 2022 4:10 am
Never, we extrude only one puck per record.
We have other different stains sometimes:
misjah
Re: Label issues
Post: # 61312Unread post misjah
Fri Aug 19, 2022 1:04 pm
Sure you can but there’s a reason it’s usually done on lacquer/dmm.
Ketaman
Re: Cracked Labels
Post: # 61339Unread post Ketaman
Mon Aug 22, 2022 5:51 pm
The marks you're getting look more like they are coming from an issue with your pucks/compound... Are you pucks homogenous and do they have a good surface finish when they come out of the extruder? Perhaps you don't have your extruder temps set correctly. I have had this issue before and it usually resolves once you get your extruder temps and/or screw speed dialled in.
filiperibeiro
Re: Cracked Labels
Post: # 61358Unread post filiperibeiro
Thu Aug 25, 2022 3:53 am
So why do these spots only happen when I put a label on the record? When I put a puck without a label it is always clean and there are no stains on the record. :|
Re: Cracked Labels
Post: # 61364Unread post Aussie0zborn
Thu Aug 25, 2022 2:06 pm
This is getting more interesting.
How about you tell us what you’re using so we’re not wasting time speculating about what your setup might be. This might give you more accurate responses.
filiperibeiro
Re: Cracked Labels
Post: # 61392Unread post filiperibeiro
Tue Aug 30, 2022 9:44 am
ok so this is our settings of the extruder and the aspect of our 140g puck right now.
let me know if you need more information about the extruder, please.
thanks!
Re: Cracked Labels
Post: # 61420Unread post Aussie0zborn
Sat Sep 03, 2022 5:53 am
Your PVC puck looks somewhat dry. Can you leave a fingerprint on it?
filiperibeiro
Re: Cracked Labels
Post: # 61436Unread post filiperibeiro
Tue Sep 06, 2022 3:51 am
nope. can't leave a fingerprint on it.
