Presses
snyderkevin65
Presses
Post: # 52981Unread post snyderkevin65
Thu Apr 25, 2019 7:52 am
Hi Everyone,
I've been researching record presses and came across this. I can't seem to find much info about it, or reviews. I was wondering if anyone has any information about this?
Thank you,
https://www.alibaba.com/product-detail/Vinyl-record-press-machine-vinyl-press_60582631281.html?spm=a2700.7724857.normalList.2.19323348pOCdTR&s=p
llary
Re: Presses
Post: # 53007Unread post llary
Mon Apr 29, 2019 2:36 am
That is a generic hydraulic column press and in my opinion it's not suitable for vinyl pressing at all, let alone all the important associated parts that are missing. Also great that it has zero safety features whatsoever.
If you are able to turn this into a working press your time would be better spent restoring an old press with a verified design.
If you are looking for a turnkey solution then this is not it, you can look at Newbilt / Pheenix Alpha / Viryl.
