Hydraulic System
Ragnar
Hydraulic System
Post: # 52604Unread post Ragnar
Mon Mar 18, 2019 11:04 am
Hello,
I am looking for information. What would be the best hydraulic solution for 1-2 Toolex 12" automatic presses?
Best.
Re: Hydraulic System
Post: # 52609Unread post Aussie0zborn
Tue Mar 19, 2019 9:17 am
You might need to specify which version of the press do you have - single pressure or double pressure?
Do you have instruction manual and drawings?
Ragnar
Post: # 52610Unread post Ragnar
Tue Mar 19, 2019 9:38 am
We have double pressure press and some two pumps old hydraulic unit, but it makes oil quite hot. I need to replace pumps, but maybe would be better to rebuild all system that would not running all time, only pressure is needed. Is someone had experience and could share?
andybee
Post: # 52649Unread post andybee
Fri Mar 22, 2019 4:31 am
Hello Ragnar!
IMHO the best way is, to contact your local hydraulic supplier for help & service,
they are mostly very experienced and will supply you with all needed parts etc.
This will cost some euros, but at the end of the day, you have something good.
good luck!
Andreas
chris king
Post: # 53089Unread post chris king
Fri May 10, 2019 7:32 pm
sent you message. I have brand new system we had built to test 12 inch presses we were restoring.. will run 4 to 6 presses. includes full tank of brand new oil, hundreds of pounds worth of hoses and valves. its ready to plug and play
andybee
Post: # 54471Unread post andybee
Thu Nov 07, 2019 7:39 am
you will normally always need a hydraulic oil cooler, because the oil is
always under full pressure, when the cooling cycle is active...
there are systems with water or air available...
good luck! :wink:
