Record Press Manufacturers New machines only
Post: # 49619Unread post mossboss
Thu Mar 08, 2018 5:39 pm
Hi all
I think is about time that we have a list of the people around the globe who make new presses as well as moulds to suit their machines as well as other services available or offered to the Vinyl Record Pressing industry
Please provide a short description of products available also contribute links with web address and contact details
I would have thought that most if not all involved do visit here so the invitation is extended to manufacturers first, of course any one else can also chip in
Once sufficient data is gathered we can do a permanent page for ppl to access
best
and
thanks
SibertInstruments
Re: Record Press Manufacturers New machines only
Post: # 49622Unread post SibertInstruments
Fri Mar 09, 2018 3:51 am
Hi Chris
We are Sibert Instruments Ltd based in the UK www.sibert.co.uk, we have been long established in the early days of the Vinyl industry and then into Optical Disc as manufacturers of Punching and Finishing equipment for Stamper preparation.
We currently have a new Stamper Centre Punch available and we are in the process of developing a new Back Finisher which should be abvailable around the middle of the year. Addtional products are also on the road map.
We can also service and support for our older equipment which is still in use in the Vinyl industry.
We are also very happy to speak to customers who need specific equipment that might be difficult to maintain or hard to find.
Our customers are world wide.
Kind regards
David
AD1207
Post: # 49625Unread post AD1207
Fri Mar 09, 2018 12:15 pm
Hi everyone,
We, Pheenix Alpha, offer new fully automatic pressing machines based on the Toolex Alpha AD12. The mechanical part of the machine is built according to the original spec. Since we are the sucessor of Toolex Alpha we have all the original drawings for the pressing machine and we have the know-how. Most of the people working here have been working at Toolex Alpha in the past.
The AD12 is updated with new control system and safety measures that complies with today's safety standards.
The standard AD12 comes with one spindle output station. We offer dual output station with automatic cooling plate deposition or automatic sleeving unit as options. Also there's an integrated hydraulic pump unit as an option. The AD12 can run 12" 10" and 7" format.
Also we offer the original Toolex Alpha moulds and preforming tool for stampers.
To this date, our installed base of new AD12's is 20+ machines.
We are currently working on the "resurrection" of the 7" AD7. Our goal is to have the first batch ready by the end of 2018.
As I have explained in the thread about our pressing machines https://www.lathetrolls.com/viewtopic.php?f=10&t=6807 we are working on a new website that will be launched within short (I will post here once it's up and running). But you can find contact info on our current website http://www.pheenixalpha.com. We are also on facebook https://sv-se.facebook.com/pheenixalpha/.
Please have a look at our promo video filmed at https://www.deepgrooves.eu/ :
https://youtu.be/IExzO_gtVIc
In any case everyone is welcom to contact me for whatever reason :D
Best regards,
Niklas Poblenz
Pheenix Alpha AB
niklas.poblenz@pheenixalpha.com
+46 8 598 933 62
Post: # 49692Unread post mossboss
Wed Mar 14, 2018 1:23 am
Thank you fellas. More to come?. Any one can chip in
Best.
Record Troll
Post: # 49713Unread post Record Troll
Thu Mar 15, 2018 12:56 pm
Record Products of America (RPA) supplies all types of molds for all brands of record pressing machines. RPA molds are the industry standard for making quality flat records. RPA also manufactures stamper finishing equipment to properly center punch, trim & form stampers so that they properly fit the molds. New pressing equipment from Pheenix and NewBilt are supported. In addition, RPA provides dinker machines for punching larger 7" center holes and automatic label punch machines to facilitate Vinyl recycling.
Contact
RPA. Inc.
700 Sherman Avenue
Hamden, CT 06514 USA
Tel: 203-248-6371
Email: info@recordproducts.com
