Inside-Out Cuts
antipenultimate
Inside-Out Cuts
Post: # 44083Unread post antipenultimate
Thu Sep 22, 2016 2:46 am
I was wondering if there is anyone is aware of anyone currently cutting with inverted grooves, ie: where the record plays from inside, near the label to the outside of the record.
Edit : the term is "inside-out" cuts. -Aussie.
Gridlock
Re: inverted grooves
Post: # 44084Unread post Gridlock
Thu Sep 22, 2016 5:12 am
Maybe we need a list of disk cutters with this option. Presto k series, maybe j series? Not sure about the presto overhead models. Neumann scully and haeco im sure. Fairchild probably not? Im not an expert
Re: Inside-Out Cuts
Post: # 44093Unread post Aussie0zborn
Fri Sep 23, 2016 6:24 pm
Some Scully lathes - yes.
rsimms3
Re: Inside-Out Cuts
Post: # 44095Unread post rsimms3
Sat Sep 24, 2016 5:58 pm
Any of the Presto overhead machines could cut inside out with the correct feedscrew. I think all the console Presto models with fixed feedscrews could cut both ways also. Some (most/all?) of the Fairchild models could be switched in the gear box to reverse direction to cut inside out as well.
Fairchild
Voxster1965
Re: Inside-Out Cuts
Post: # 44096Unread post Voxster1965
Sun Sep 25, 2016 12:51 am
I have a Presto K-10 with both outside-in and inside-out feed screws. Inside-out is less problematic in relation to swarf management.
drdub
Re: Inside-Out Cuts
Post: # 44125Unread post drdub
Tue Sep 27, 2016 3:18 am
we do that a lot on souri's machine.
cheers mex
satan spins vinyl
*** www.drdub.com ***
misjah
Re: Inside-Out Cuts
Post: # 44486Unread post misjah
Mon Oct 24, 2016 4:29 am
I do too
