New vinyl record presses
untitledthe
Re: New vinyl record presses
Post: # 37747Unread post untitledthe
Sun Oct 04, 2015 11:55 am
Aussie0zborn wrote:See this short video clip : https://m.youtube.com/watch?v=aOo76IAQ8Jw
Im pretty suprised a warmth lamp is enough to make the pvc granulate soft enough for the press,..
This stuff isnt that tuff it destroys the stamper would you put in less heated granulate in the press by accident?
andybee
Post: # 37828Unread post andybee
Wed Oct 07, 2015 6:00 pm
Post: # 37834Unread post Aussie0zborn
Thu Oct 08, 2015 5:55 am
Ah yes. Andy B's link shows the Werner & Pfleiderer down-acting press with top mounted cylinder. W&P is a world leader in plastics machinery. When EMI needed a good extruder for the legendary EMI 1400 auto press, W&P were the company selected to make the EMI twin screw extruders for them.
untitledthe wrote: Im pretty suprised a warmth lamp is enough to make the pvc granulate soft enough for the press,..
Good question. This is why splatter colour records are usually noisier. There is another method that allows the loose coloured pellets to heat up to almost the same temperature as the vinyl cake and these records have no noticeable noise. The now defunct Teldec in Germany made perfectly quiet splatter records back in the day.
Post: # 37836Unread post mossboss
Thu Oct 08, 2015 9:24 am
andybee wrote:take also a look here:
https://www.youtube.com/watch?v=bGqL0jgS_XU
Very much the case for 7" records
I would like to see a 12" machine with a top mounted cylinder
I have yet to see one successfully implemented
I should have been more precise and say 12"
Never mind
The minders will always pick one up He He
best
andybee
Post: # 37845Unread post andybee
Fri Oct 09, 2015 6:47 am
The W&P has changeable moulds, so this press also does 12inch,
There was also a press from LAUFER arround, also top mounted cylinder,
was used before the W&P to press pictures in ALL SIZES.
Post: # 37852Unread post mossboss
Fri Oct 09, 2015 2:55 pm
Well maybe the Germans had it sorted out,
The top cylinder presses at some place we all now do only picture discs or 7",s and they have a few
My observations and their comments, on these machines, they have tried for years to get them right for 12" but to no avail
best
Post: # 37853Unread post Aussie0zborn
Fri Oct 09, 2015 3:11 pm
12" press with top mounted cylinder:
Post: # 37879Unread post mossboss
Mon Oct 12, 2015 9:10 am
Impressive cycle time, similar to the very very early EMI trimming system but that had a rotating knife rather than a circle cutter setup
A very good way of cooling down records before trimming to get fast cycle time
Best
untitledthe
Post: # 38323Unread post untitledthe
Wed Nov 04, 2015 10:51 am
Aussie0zborn wrote:Good question. This is why splatter colour records are usually noisier. There is another method that allows the loose coloured pellets to heat up to almost the same temperature as the vinyl cake and these records have no noticeable noise. The now defunct Teldec in Germany made perfectly quiet splatter records back in the day.
By putting them in the oven, or? Now this is something you'll find out in practice, i guess it would come down to find the right temperture between to hard pellets and melted ones if so.
untitledthe
Post: # 40236Unread post untitledthe
Thu Feb 04, 2016 10:09 am
Nice article on Viryl Technologies with serious automatic record presses;
http://www.theglobeandmail.com/report-on-business/small-business/startups/canadian-firm-comes-to-the-rescue-of-vinyl-lovers-by-building-new-pressing-machines/article28507701/
I think a pretty big deal when this is in full operation.
untitledthe
Post: # 41146Unread post untitledthe
Mon Mar 07, 2016 11:34 am
Looks like a thoughed through design as far as you can make up from this render. Exciting.
untitledthe
Post: # 42218Unread post untitledthe
Fri Apr 29, 2016 1:02 pm
The Newbilt recordpresses for the American market are coming allong nicely as you can see on their website;
http://www.newbilt.com
untitledthe
Post: # 43314Unread post untitledthe
Fri Jul 15, 2016 3:33 pm
All sort of recordpressing equipement by RAND Muzik Germany;
http://www.rand-vinyl-record-machines.com/
Oliver-Ibiza
Post: # 43315Unread post Oliver-Ibiza
Fri Jul 15, 2016 5:01 pm
But no new record presses available from Rand??
