Pressing and plating
Nickou
Post: # 21888Unread post Nickou
Tue Nov 20, 2012 5:20 am
Hi Guys
I need to plate and press from lacquers in the New York Area
Any recommendation ?
Thanks
Yann
Nickou
Post: # 21889Unread post Nickou
Tue Nov 20, 2012 11:58 am
Please ! I need some help !
I know they is a thread somewhere in the forum with a list of pressing plant but I can t find it !
Nickou
Post: # 21890Unread post Nickou
Tue Nov 20, 2012 11:59 am
founD
Post: # 21891Unread post opcode66
Tue Nov 20, 2012 12:04 pm
FYI, most of us have our plating done at Mastercarft in New Jersey.
A lot of pressing plants don't do galvonics anymore here in the US.
Serif
Post: # 21904Unread post Serif
Wed Nov 21, 2012 2:10 pm
I have deciphered the conflation between the Galvanic cell and the Brugnatelli (eletro-deposition) cell. When Luigi Galvani stopped using static electricity for frog-leg bioncs and went for chemical-derived electricity (in the form of the Voltaic pile), he was using copper and zinc electrodes' passive potentials. The chemical redox between them made the frog leg nerve twitch the muscle, just like the static-charged scalpel had done. Since the Voltaic pile used zinc, when one electro-deposits zinc (coating), he might call it Galvanizing. But to be "galvanized" is actually to become like the frog's leg muscle - "brought to action through outside motivation." Meat puppets from hockey stix, running on auto-pilot (you know).... (;
Verily. it was the _other_ Luigi: Luigi Brugnatelli, who is the father of electro-deposition, which is when a direct current is directed _into_ the cell, rather than pulled _out_ of it.
An important distinction which will doubtless go disregarded, but which is still fun to point out, in case anyone cares...
- Andrew
