Vinyl Record Centre Hole diameter
W.B.
Re: Vinyl Record Centre Hole diameter
Post: # 62220Unread post W.B.
Thu Jan 26, 2023 6:24 pm
0.286" is also roughly equivalent to the agate measuring system (in 14ths) of 0.285714285714" . . . or 2/7. The full mm of that is 7.25714285714 . . . - or rounded off, 7.26mm.
