VR Clear box heating modification
Hi folk..
I have just upgraded my VR with a 275w heater above the platter. Wow what an improvement and even heating compared to the standard side lighting (hard to get globes for them too now!)
Question - I am looking at encasing the VR in a clear box (measurements are: 800mm wide x 400mm High x 700mm deep)
Has anyone sourced anything made already? eg: storage boxes? I would like a flip top lid to access the front of machine, obviously.
If nothing similar is already exisiting (yes! I have googled!!) then I may produce this from some clear plastic sheeting.
The reason for this is to keep the heat within box, and to keep dust out. win win..
If I make these, I may look at posting some pics, and would be happy to sell, or help with this much needed improvement.
Cheers!!
Cheers!!
- trailerparkjesus
Re: VR Clear box heating modification
This works well but you are increasing static! There are anti static fans with heaters built in on ebay, that is what we use if needed.
Hi David,
Afraid I can't help you with your box idea but was wondering, could post the make & model of that 275w heater you're using please (and/or where you bought it from)?
Hi there,
If so, give http://www.inperspextive.com a shout out
Best Regards
Soulbear
Something like this ((Only Bigger!!)) ((https://www.lathetrolls.com/viewtopic.php?f=15&t=6818&p=46875&hilit=lazarus#p46875))Hi Trolls,
Due to being Inordinately busy following my house move, I've not had time to make much more progress with this Lazarus Lathe Project. I did however find time to send an email or two to Paul @ http://www.inperspextive.com
Paul has made for me a Totally Superb Acrylic Cover which fits the DR33C like a Charm. I thoroughly recommend his workmanship to any Lathe Trolls needing any similar Covers for their own Projects
Best Regards
Soulbear
Thanks so much! will look this up!
I am in Australia. Bunnings have them for $10 on special. I can grab you one (or anyone who pM) , just let me know.. they heat the disc perfectly and evenly.. and quickly!!
- Aussie0zborn
David, do you have a link to the heater at Bunnings? Thanks.
They are clearance items but will post a photo soon..
I might buy a few next time I’m in bunnos…
Here is the brand..
- Aussie0zborn
Thanks David!
Hey David,
Hope you're doing great. Would you mind posting a picture of your installation?
I'd love to see how you set it up
Thanks
Ben
Thanks
Ben
