Sound Scriber
Sound Scriber
Has anyone determined what was the material used in Sound Scriber disks?
I am thinking Lexan (easily embossed) might be a substitute....
the precise mixture of materials can be read in some of the soundscriber patent applications - find them at freepatents.org
As I remember, resin is a main ingredient.
I have myself experiemented with a lot of different plastics - It seems that what works best is plastic that is soft, but somehow rigid as well.
You will have to eperiment a bit.
- alienmanstk
I can't point you to a specific type of plastic.
First you could try to find some of the original discs, they have very little surface noise. Secondly you could try a papershop that sells differnt types of plastic and buy fx 10 different types.
It has to be quite thick and rigid, 'floppy' plastic tends to produce very much surface noise.
Be creative! try to cut out plastic from covers, lids etc. and make test cuts.
do a google search on 'amishfan' 'soundscriber experiments'
heres is a description, mostly on what does NOT work.
good luck
good luck
- alienmanstk
hey tape! that's a great website, I have already started experimenting!!! Just one more question: Will this dull down your cutting needle? I know that the needles on the soundscriber is quite hard to dull down, but what about a recordio needle?? Will that become dull by using one of these plastics??? Thanks so so so much for your help!
I don't know how long a soundscriber needle will last - propably almost forever - it does not cut, it embosses grooves.
If I were you, I would not attempt to cut anything else than lacquer discs with a recordio - the needle will last one, maybe two records, depending on the material you are cutting in, and the needle (saphire, steel etc.)
Maybe if you heat the needle while cutting the needle will last longer, but I can't reccomend it.
- alienmanstk
you will have to first slow down a bit:-)
and read what I wrote again - the life of the stylus depends on:
- the type of needle
- type of recording media
- your abillty to set up your cutter correctly.
steel needles will last very short time, saphire longer.
Search the posts in here, there are probably answers to a lot of your questions..
Soundscriber disks
Thanks , Tape ....you're very helpful.
For those others who ask about needles, it's true that barring disasters, the recording needle tends to last forever...my machine is very old yet the needle, under a microscope, seems as good as ever. And as you mention, one does NOT want a chisel point, but rather a rounded point, somewhat like an old steel phono needle.
Soundscriber disk material
More on this: one relevant patent says the disks are of "Vinylite", a co-polymer of vinyl chloride and vinyl acetate. Thanks to Tape for pointing me in this direction.
speakng on embossing discs...
do those embossed cut records play on a normal turntable?
[Q/::][Q/::]
PLaying Soundscriber on normal turntable
Re your question on playback of Soundscriber disks on a normal turntable, this can be done but the sound level is quite low with poor frequency response. Probably has something to do with the needle point profile.
Soundscriber center hole
I am trying to make my own blanks to use with a soundscriber machine. It's very easy as the machine will emboss most kinds of plastic. However the center hole is square and 'larger' than a normal centerhole in the sense that it is a 'squared' circle. This means that discs with a normal center hole can not be used without destroying the hole.
Any ideas on how make a square hole?
I have tried with a knife and various other tools, impossible to get a wel defined proper looking hole.
thanks in advance
thanks in advance
I would try using the clear plastic "divider" sheets sold for binders. Not the colored textured ones, but the ones with smooth surfaces. The plastic would be very close to the original disks. It's about the same as X-Ray film, but without the emulsion. An exacto knife would be used to make the square hole.
http://www.paperpunchesstore.com/41_4_Inch_Reach_Template_Punch_125_12929.html
They say rectangular dies are available for this punch, maybe you could get a custom square for it.
