Turntable for 14" lacquers/mothers
Dntoddy
Post: # 59587Unread post Dntoddy
Fri Oct 08, 2021 1:51 pm
Sorry if there is already a topic on this, I couldn't seem to find one.
I am looking for a good turntable for listening tests on 14" lacquers and mothers. Preferably one which can switch off the automatic rotations so I can do small turns by hand to locate specific areas in the grooves.
If there are any particular models which work well for this task I would be grateful to be shown which ones.
misjah
Re: Turntable for 14" lacquers/mothers
Post: # 59588Unread post misjah
Fri Oct 08, 2021 2:16 pm
I use EMT but you can play 14” lacquers on 1210’s too
leemichael
Post: # 59589Unread post leemichael
Fri Oct 08, 2021 2:27 pm
…..but you can play 14” lacquers on 1210’s too
Do you mean SP10? 14” won’t fit on a 1210 unless you drop the strobe tower and relocate the tonearm.
misjah
Post: # 59591Unread post misjah
Fri Oct 08, 2021 3:20 pm
No i mean 1210…fits perfectly fine if you leave original rubber and an extra slipmat. Played 100s on it. Try it.
Dntoddy
Post: # 59593Unread post Dntoddy
Fri Oct 08, 2021 4:13 pm
Thanks for the quick replies.
We have a 1210 but it seemed too tight I will try an extra mat.
I will also check out the EMT.
Dntoddy
Post: # 59594Unread post Dntoddy
Fri Oct 08, 2021 4:16 pm
Does the sp10 work well for this?
martinstamper
Post: # 59610Unread post martinstamper
Tue Oct 12, 2021 4:42 am
Cheap option is the Audio Technica ATLP5 - it will fit a 14" with no modification at all. If you shop around the vintage hifi world there are hundreds of transcription turntables that will accommodate a 14" disc without any modification too, it just might involve traipsing around a few hi-fi dealers to try them out.
Dntoddy
Post: # 59612Unread post Dntoddy
Tue Oct 12, 2021 4:39 pm
Great Martin thanks for this
