Is there a good reason not to cut 78 lps?
Jesus H Chrysler
Post: # 58518Unread post Jesus H Chrysler
Wed May 05, 2021 11:53 pm
I just got a 78 rpm Seeburg home library jukebox and my 78 collection is lacking, so I wanna cut some new records for it. It holds 100 10 or 12" discs. I know on older lathes where the carriage is coupled to the platter, the play time is limited by the speed, but that's not the case on a VR, so is there any reason I shouldn't cut a 15 minute or more 78 rpm side other than stylus wear?
SueDenim
Re: Is there a good reason not to cut 78 lps?
Post: # 58521Unread post SueDenim
Thu May 06, 2021 7:57 am
78 rpm records have a much wider 'coarse' groove than that of an LP or 45 rpm single's 'micro-groove'.
Your Seeburg will be fitted with a coarse groove stylus which is around 2.5-3 mil tip diameter. Whereas your VR has a cutting stylus designed for micro groove, which is around 1 mil.
In other words, your Seeburg will struggle to track the grooves of the records cut by your VR correctly (if at all).
If you don't intend to put any real 78s on your Seeburg and only want to stick to the records you cut on your VR, then I suggest you replace the styli in the Blackhead cartridge with ones designed for 45 rpm records. These can still be bought from various places... in the US, I suggest here: http://www.needles4jukeboxes.com/seeburg_needles.htm
Don't forget to cut you records in mono!
As an aside, 78 rpm records were originally made out of a semi-natural material called Shellac. The maximum playing time was established by the maximum groove LPI that you can cut into Shellac before the wide coarse grooves begin to deform and collapse in upon themselves. Usually around 120 LPI.
handcut
Post: # 58522Unread post handcut
Thu May 06, 2021 8:49 am
Also, some 78 jukes need an eccentric runout groove to activate the auto-changer mechanism
SueDenim
Post: # 58523Unread post SueDenim
Thu May 06, 2021 11:56 am
True enough, but not many. All the Golden Age boxes from the mid-30s onward that I've had experience with don't need it to trip the cancel relay.
Certainly the mechanism in the Seeburg Library Unit doesn't as it's the exact same as the M100A which I own :D
It has trip 'sensors' for both eccentric and non-eccentric lock grooves so the best of both worlds!
Post: # 58524Unread post markrob
Thu May 06, 2021 11:07 pm
Correct me if I'm wrong, but I think you can cut an acceptable 78 era groove with a microgroove stylus as long as you cut deep enough such that the groove width is wide enough for the 3 mil tip playback stylus to ride at the proper depth. The bottom of the groove will have a sharper profile and be deeper as compared with a period cutting stylus, but that shouldn't matter. As was stated, you will need to run at 96-120 Lpi to avoid overcuts. I assume you are not trying to cut a lacquer disc for playback, but rather plastic blank. I would expect the mech would have trouble with a thin lacquer disc and given how heavy these machines track, might not last too long. Also, a lacquer disc might not have enough coating to allow you to cut deep enough to achieve the desired groove width without hitting the aluminum base.
Jesus H Chrysler
Post: # 58525Unread post Jesus H Chrysler
Fri May 07, 2021 12:51 am
I'm still new to the world of Seeburg jukes but I think I have the red head on it, which would be ok with microgroove. It sounds like shit on my shellac 78s. I think cause it's bottoming out in the groove. I'll just have to cut some tests to find out.
SueDenim
Post: # 58526Unread post SueDenim
Fri May 07, 2021 4:31 am
In that case your Seeburg must have been modified at some point with a completely different tonearm as the original mounting would only accept the first generation of Pickering 'Blackhead' carts.
Would love to see some photos if you have time.
And yes, from your description, it sounds as though it's already set up for micro-groove playback... although it's odd that it is also still set for 78 rpm as the typical modification usually also changed the speed to 33.33 at the same time.
Jesus H Chrysler
Post: # 58534Unread post Jesus H Chrysler
Sat May 08, 2021 2:09 am
Here's a couple. One I took and one snatched from the auction page
Jesus H Chrysler
Post: # 58535Unread post Jesus H Chrysler
Sat May 08, 2021 2:26 am
I think this an m100a or possibly m100b mech? Don't know if it's original to the unit. I'll check the SN# when I get a chance to narrow down when it was made.
SueDenim
Post: # 58537Unread post SueDenim
Sat May 08, 2021 8:27 am
Thanks for the photos - could you take a close up of the cartridge and tonearm please?
It's hard to be sure from the photo above, but the tonearm looks like the original which makes me wonder what type of cartridge is currently fitted as it doesn't appear to be a Blackhead!
Would like to help you get to the bottom of this minor mystery :)
btw, it's definitely a M100A mech, not a B. Although it looks similar, the B mech is 45rpm only and is quite different under the hood from the A.
Jesus H Chrysler
Post: # 58540Unread post Jesus H Chrysler
Sat May 08, 2021 10:45 pm
It looks just like the redhead cartridge on the needles site.
Jesus H Chrysler
Post: # 58541Unread post Jesus H Chrysler
Sat May 08, 2021 10:50 pm
Also , thanks for your insight, Sue. You're a credit to this group.
SueDenim
Post: # 58543Unread post SueDenim
Sun May 09, 2021 6:31 am
You're more than welcome mate - thanks for the vote of confidence!
Hmm... interesting. I'd still like to see a close up of the cartridge and tonearm if you have the time.
The reason is that something doesn't make sense. From what I can see from the mechanism photo, the cartridge is fixed to the tonearm using the original type-A Blackhead connections.
Whereas a Redhead cartridge would have a 2-pin connection which usually requires a completely different tonearm.
I'm thinking that perhaps there is some kind of adaptor enabling the use of 2-pin carts on an original 'A' type tonearm... but I'd need a better look to be sure.
Thanks,
Jesus H Chrysler
Post: # 58562Unread post Jesus H Chrysler
Mon May 10, 2021 7:08 pm
SueDenim
Post: # 58565Unread post SueDenim
Tue May 11, 2021 4:30 am
Hey thanks mate.
Yup, as you thought, that is a genuine Redhead cart but (as I suspected) connected to an original 'A' tonearm by means of some type of adaptor.
Would like one of those adaptors myself tbh!
So, the upshot of this is that you are indeed all set up to play back microgroove 78s cut on your VR :)
Like I said before, make sure you sum your channels to mono before you cut and I suggest you keep the max amplitude around +6dB.
All the best...
Jesus H Chrysler
Post: # 58595Unread post Jesus H Chrysler
Mon May 17, 2021 12:49 am
All good as I suspected. I've got a manual on order so I can sort out the preamp. There's some loose wires and some suspect repairs done that I need to address. Then I I can start poking around in the Capehart flip over 78 changers I got in the same sale. (After I finish replacing the floors and changing the brakes in my car.) .
Tim w
Post: # 58689Unread post Tim w
Mon May 31, 2021 11:41 am
This is up my street. Check out the Talking Machine Forum. There’s a new post about Colin Hancock making his own acoustic 78’s
