VR with Technics SP10 MkII : Max Weight stylus
Discomo
Post: # 58147Unread post Discomo
Sun Mar 28, 2021 6:32 am
I recently bought a Technics SP-10 mkII to hopefully finally get rid of the wow problems I'm having with specific music (vinylrecorder).
Now waiting for the table to arrive.
Can anyone tell me on forehand how much weight I can give maximum at the stylus in order to stay free from wow issues?
I vaguely seem to remember it can have 20 gram and with 22 gram wow issues start to emerge. But can't find back this post.
Should I better buy a mkIII instead, or is it overkill.
Soulbear
Re: Technics SP-10 mkII : Max Weight stylus
Post: # 58151Unread post Soulbear
Sun Mar 28, 2021 8:10 am
SP-10 mk2
Motor: brushless DC motor, electronic rectification, quartz-controlled phase-locked servo circuit
Plater: 320mm 2.9kg aluminium
Speeds: 33, 45 and 78rpm
Pitch control: 10% (mk2P)
Starting torque: 6kg-cm
Build up time: 0.25s to 33rpm
Braking time: 0.3s from 33rpm
Speed fluctuation by load changes: 0% within 5kg-cm :wink: :wink: :wink:
Wow and flutter: 0.025% WRMS (JIS C5521)
Discomo
Post: # 58152Unread post Discomo
Sun Mar 28, 2021 8:19 am
Thank you sir! :)
But I'm afraid I'm more the simple type... tried to pull the torque with 5kg per cm, but the pick up seems to keep slipping from the table.
PMST
Post: # 58163Unread post PMST
Mon Mar 29, 2021 5:06 am
Wow won't be an issue. Never heard of wow at 22g, or maybe even at all using a SP10 MKII on a VR? Within normal limits of course, but in terms of cutting, no matter the weight, I'm pretty sure wow won't be a problem
Discomo
Post: # 58171Unread post Discomo
Tue Mar 30, 2021 1:44 pm
Thanks. Cutting will be so much easier then. Should have exchanged the tables long before.
Do you work with an SP10 mkII ?
PMST
Post: # 58176Unread post PMST
Wed Mar 31, 2021 2:41 am
Yeah since I used the SP10 MKII it changed everything, so many noise issues have gone, +10db cuts on 12"! Cutting right from the edge ;)
Discomo
Post: # 58186Unread post Discomo
Wed Mar 31, 2021 4:24 pm
I read there should be some adjustments done. Can you tell me which?
Just minor ones? I read some people use a precisionplate in conjunction with the sp10 mkii. Is this necessary?
PMST
Post: # 58190Unread post PMST
Thu Apr 01, 2021 12:26 am
The run out on a SP10 is significantly less than say a 1210, but the precision plate is always good, there’s plenty of torque so if you can afford one, I’d go for it. It isn’t essential, you can get great cuts without it, but for sure it will help even the tiniest amount of run out.
In terms of other adjustments, nothing really, just the normal calibration of the overhead and cutting head for weights and diamond travel to the center of the blank
Discomo
Post: # 58193Unread post Discomo
Thu Apr 01, 2021 2:59 am
Thanks, I appreciate your advice.
2bitcomputer
Post: # 58214Unread post 2bitcomputer
Sat Apr 03, 2021 5:20 pm
Maybe there is something wrong with my SP10 but it does NOT like having the precision plate on it.
Goes into some sort of cogging motor error.
It runs beautifully without the precision plate, and I can cut all the warped discs out there (that everybody sells) with no problems :wink: :)
SueDenim
Post: # 58218Unread post SueDenim
Sun Apr 04, 2021 6:08 am
Just to confirm that your SP10 is a mkII (or possibly a mkIII), correct?
If so then, from the symptoms you describe, it sounds like you're significantly down on torque from level it should be at. First thing I'd do is have someone who knows what they're doing service the electronics in both the turntable and power supply.
Re: VR with Technics SP10 MkII : Max Weight stylus
Post: # 58238Unread post tragwag
Wed Apr 07, 2021 10:39 am
does anyone have a precision plate that works with the SP15? both versions I've had cover up too much of the center hole to be usable
Discomo
Post: # 58247Unread post Discomo
Thu Apr 08, 2021 8:40 am
As a side note:
I've placed the SP10 MKII under the VR.
I was expecting a difference in height (compared with the 1200 MKII, but it's almost exactly the same. About 9.2 cm.
The rubber mat which came with the SP10 MKII is quite thick though.
Discomo
Post: # 58248Unread post Discomo
Thu Apr 08, 2021 9:51 am
Nice thick mat which levels the SP10 MKII
Discomo
Post: # 58249Unread post Discomo
Thu Apr 08, 2021 10:15 am
The main reason why I stepped into this new turntable project is, not so much the wow problem.
The main reason was a constant recurrence of swarf issues, the last months. After having tried everything, I noticed when I increased the weight of the stylus, swarf issues disappeared.
Only on the 1200 MKII, wow issues appeared, or even extremely fully false music.
I can confirm, after a few testcuts, for now the swarf problems have gone, while keeping a fully clean wow/flutterless cut.
(Btw, I have the weight of the stylus at 24 gr at the outer rim and it's about 22 close to the centre, which sort of answers my question in a very positive way)
Hoping now it stays like this.
Strangely I've never had this kind of issues in the previous 3 years.
Perhaps it's because of severe low humidity (although raising the humidity didn't really help).
Discomo
Post: # 58250Unread post Discomo
Thu Apr 08, 2021 10:43 am
Maybe it's possible to have someone produce it for you?
Basically it's only a metal disc if I'm correct
HannesFTL
Post: # 58262Unread post HannesFTL
Thu Apr 08, 2021 4:30 pm
I run a SP10 myself with nice results. I didn't make any height adjustments. I had a custom mat made though. My SP10 mat wasn't close to some kind of flat.
About weight. I think a SP10 can handle more weight than you'll ever need. So focus on your groove width/depth with a microscope and adjust accordingly.
Happy 12" cutting!
dubplatecutter
Post: # 61203Unread post dubplatecutter
Tue Jul 26, 2022 9:20 am
Hi!
It looks that your head is not paralell to the plate.. how do you adjust the stylus? i always have little problems to find sweet spot.
thanks, peter
Discomo
Post: # 61235Unread post Discomo
Wed Aug 03, 2022 7:30 am
It’s the angle of the photo which makes it look not parallel. It’s maybe 5% off but a little off doesn’t matter that much. With many parameters in play- weight stylus, counterweight, angle it’s just a matter of fiddling around. Your VR is different from others so the setting is unique as well- within reasonable limits
Discomo
Post: # 61236Unread post Discomo
Wed Aug 03, 2022 7:33 am
Happy 12" cutting!
I simply flipped the mat upside down. I added Souri’s mat on top but this isn’t even necessary.
Works perfect and no level issues.
