Vinyl Recorder T560 Overhead Motor
SueDenim
Re: Vinyl Recorder T560 Overhead Motor
Post: # 56904Unread post SueDenim
Mon Sep 28, 2020 9:10 am
This is truly fantastic investigative work everyone - top notch! :D
Everything I've come to expect from this community...
handcut
Post: # 56905Unread post handcut
Mon Sep 28, 2020 9:32 am
So I contacted Faulhaber directly and they put me in touch with their UK engineer. I'll let you all know the outcome as soon as possible. Thanks for all the support... The last bit of hair I had has turned completely grey the past few weeks!
jonty2k
Post: # 56906Unread post jonty2k
So, also looking at Ben's photos, the capacitor is sitting on top of a board that is attached to the rear around the connections, if it is a Faulhaber, the model number would usually be stamped in the black plastic (under the board) ;-)
handcut
Post: # 56908Unread post handcut
Mon Sep 28, 2020 9:39 am
The cap was soldered directly across the terminals on mine, identifiying marks removed from the plastic body (though this could've happened when I was digging out the silicone) and also the gearhead (again, could've happened when I was removing the gaffer tape).
jonty2k
Post: # 56909Unread post jonty2k
Mon Sep 28, 2020 9:44 am
Aha.. thats a shame, at least a bit closer anyway :-)
SueDenim
Post: # 56910Unread post SueDenim
Mon Sep 28, 2020 9:47 am
Given how Souri physically removed all identifying marks on every other VR component I've come across (i.e. ICs, external precision motor, drive coils etc.) then I doubt you had anything to do with destroying the ones on the motor and gearhead mate.
SueDenim
Post: # 56912Unread post SueDenim
Mon Sep 28, 2020 9:55 am
Knowledge! :D
chrisdexta
Post: # 56918Unread post chrisdexta
Thu Oct 01, 2020 7:40 am
Service manual idea. Brilliant - happy to chip in and do the design / layout (am a designer).
handcut
Post: # 56942Unread post handcut
Tue Oct 06, 2020 6:10 am
Is anybody with a working VR able to do me a solid and time the RPM of the black wheel when the groove/speed adjustment is maxed out (fully clockwise)? Thanks!
jonty2k
Post: # 56943Unread post jonty2k
Tue Oct 06, 2020 8:34 am
Hey handcut... 10 RPM at full speed :-)
handcut
Post: # 56944Unread post handcut
Tue Oct 06, 2020 8:39 am
handcut
Post: # 56945Unread post handcut
Tue Oct 06, 2020 12:29 pm
OK, so after some correspondence with Faulhaber's UK engineer, we have deduced that the motor is: Faulhaber 2230FR006S+22/2 308:1
Lead time on these is 8 weeks, just to warn you all!
Now all that remains is to have the original brass bearing housing cloned (for those just tuning in, the original wasn't straight) and we're golden.........
RedSpadeRobyn
Post: # 56948Unread post RedSpadeRobyn
Wed Oct 07, 2020 7:09 am
Bless you and your patience, Handcut! Thank you for sharing all of this info.
handcut
Post: # 56949Unread post handcut
Wed Oct 07, 2020 7:39 am
No worries, thanks to everyone who chimed-in. I wouldn't wish the stress of the past four weeks on anybody! I'll write-up the full process once I've had the parts made and everything is up & running.
Ben
Post: # 56950Unread post Ben
Wed Oct 07, 2020 12:52 pm
It's a pleasure to help you , I hope the pictures we're useful
That sense of community is what makes it so reassuring and special, since the creator is a no show!
When Souri stopped answering me when I had too many questions and troubles with the VR, I was like " where do I go from there?? all the money and time invested"
It's people like Steven from Myshank, Mark Rob and Bennett that saved my ass.
Let's keep the love and support coming, we can only grow from that and get better from this!!!
Post: # 56958Unread post tragwag
Thu Oct 08, 2020 3:31 pm
thanks Ben and others for this thread, hopefully won't need this info but it's a great resource!
Ben
Post: # 56959Unread post Ben
Thu Oct 08, 2020 3:36 pm
Forgot to mention... Tyler's the best!! lol
Sorry man!! :)
soeffingodly
Post: # 57623Unread post soeffingodly
Mon Jan 25, 2021 4:15 pm
Wanted to revisit and see if everything worked out for you in the end?
handcut
Post: # 57629Unread post handcut
Tue Jan 26, 2021 7:15 am
Still waiting on parts to be made. Pandemic has turned this into a bit of a saga, plus I thought that I'd make a couple of improvements to the design whilst it's dismantled. A properly mounted motor, replacing the gaffer tape/silicone mess and easier access for maintenance rather than blindly spraying oil into a tube...
