http://www.vinylrecorder.com Anyone know this product?
Steve E.
Site Admin
Post: # 12Unread post Steve E.
Sat Jun 25, 2005 1:50 am
Tony Remple
Post: # 68Unread post Tony Remple
Mon Aug 15, 2005 8:35 pm
would the blank discs they have work for a portable lathe cutter? is there an issue with them maybe being too hard of material for the needle to cut into?
motorino
Post: # 71Unread post motorino
Tue Aug 23, 2005 5:16 pm
hello
i try only the head cutter
dont have feedback, but support hi_quality power whitout helium
its better for cut pvc, only i cut any acetates with
i have one vestax vrx 2000 too
vinylrecorder and vestax are too expensive quality-price
i try too mucho
saludos
motorino
Post: # 74Unread post motorino
Thu Sep 01, 2005 6:15 am
if somebody needs any more information about this cutter... its a good solution in europe, here dont have a lot rek o haeco-grampian, but her sound.....dont good, very crisp, but for scratch its ok, not for audio lovers
aaron
Post: # 83Unread post aaron
Mon Sep 05, 2005 1:26 pm
Does anyone have any close-up pictures of the cutterhead of this thing? I'm really curious as to what it looks like and how it works...
thanks
-aaron
motorino
Post: # 100Unread post motorino
Wed Sep 21, 2005 4:33 pm
http://www.drdub.com/praxis/dub.wmv
a promotional video......dont coment
Guest
hey
Post: # 159Unread post Guest
Fri Dec 16, 2005 10:10 am
motorino wrote:http://www.drdub.com/praxis/dub.wmv
what's so funny about our little yehaaa video... ?
our first attempt in movie making...
motorino
Post: # 169Unread post motorino
Sun Dec 18, 2005 2:38 pm
mmm.. sorry, but isnt my video, not me
respect to all
ffwolfcone
i heard it cuts at -1 db.
Post: # 175Unread post ffwolfcone
Thu Dec 22, 2005 1:47 am
I heard it is real quite....
ameisevinyl
vinylrecorder
Post: # 181Unread post ameisevinyl
Sun Dec 25, 2005 4:09 pm
I heard a testcut of this thing,
its alright! some people here in germany say its a bit dull...
but i think it depends a lot on the person who uses it...
the trick is also: it uses diamond styli and not saphire
(we tried to cut into souris-vinylrecorder-plates with normal cutterheads...
its not possible!...you need the right cutting angle --> 15° for acetate
0° for PVC as far as i am concerned...i heard they heat up the PVC-disks with a light bulb and also with hot-water-baths but thats just rumours...
hey dr. dub you might know more?)
a better solution (maybe not for cutting PVC but for better soundquality)
is http://www.vinylium.ch --> kingston record cutter
these people were the first to build technics MK2 cutters...
check it out
mart
motorino
Post: # 194Unread post motorino
Tue Dec 27, 2005 5:38 pm
you can cut pvc with the kingston, but the pvc its good only for scratch, the pvc sound isnt good for profesional, its trhu
kingston sound its BETTER than vinylrecorder souri, the mistery its the feedback!! and more things :D
Marcos
motorino
Post: # 195Unread post motorino
Tue Dec 27, 2005 5:41 pm
do you like to made a good headcutter for pvc?
http://www.floka.com/lofi/lofihead_uno.html
:D
Marcos
Guest
well...
Post: # 197Unread post Guest
Wed Dec 28, 2005 6:22 am
motorino wrote:you can cut pvc with the kingston, but the pvc its good only for scratch, the pvc sound isnt good for profesional, its trhu
the new vinylrecorder heads do have feedback...
i am not going into the better/worse discussion, but what we learned is 2 things:
- ONLY through experience and cutting LOTS of records you achieve satisfying results. if you don't cut on a dayly basis you will not be able to produce decent records.
- outbord gear is just as imprtant as whatever cutter you use.
we cut on all kinds of blanks (souri, pressed ones, apollo) and learned that souri's machine is working fine, once you have a setup that fits your blanks. this is one of the big advantages of it: it's flexible and you can twist and turn it the way you need...
motorino
Re: well...
Post: # 198Unread post motorino
Wed Dec 28, 2005 5:11 pm
i will like listen, but compare the old one with the sc-99 vinylium...
i believe, a person, dont need a lot of time for listen the diferences
only writing my experience
regards, guest
Marcos
motorino
Post: # 199Unread post motorino
Thu Dec 29, 2005 2:32 am
a ver si aprendo un poco de inglés..
Marcos
Itsagroovething
Kingston Cutter Blanks
Post: # 356Unread post Itsagroovething
Mon May 08, 2006 10:22 pm
Hi, Can anyone tell me if you can use Vinylium Souri's blank discs for the Kingston Cutter too???
motorino
Post: # 363Unread post motorino
Tue May 09, 2006 4:56 am
if you use diamond stylus in vinylium cutterhead you can cut any pvc blank :D
of course, you can use zaphirus stylus for cut pvc...but the stylus recording time its low....
Itsagroovething
Post: # 366Unread post Itsagroovething
Tue May 09, 2006 10:32 am
Can you tell me what's the difference between a pvc blank and a reference-lite blank that Apollo supply, and where you get the pvc blanks from.
Itsagroovething
Heating Vinyl
Post: # 397Unread post Itsagroovething
Fri May 26, 2006 9:30 am
Hi, does anyone know how long you have to heat the pvc vinyl for and how warm the vinyl should be before cutting with a Kingston Dub Cutter??
jaser
Post: # 430Unread post jaser
Tue Jun 13, 2006 7:38 am
hi i have one of these machines sorry for late reply ...
sound quality depends on user .... at first i thought yeah these are ok but now i think they are amazing ........ you need a hot space tho minimum 28 degrees and each record has to be more than 42 degrees to get real good sound.... and stylus heating is different for each records depending on room temp give or take a few degrees this is important :D
