My first grooves.
My first grooves.
Well here they are!
It didn't last long before i got a swarf plug, but for a whole two or three seconds i was cutting a record!
Pretty much everything i built so far needs to be adjusted, as i expected.
3 years work for 3 whole seconds of fun. Totally worth it.
- Voxster1965
Re: My first grooves.
Get your hands on some talc for that tube my friend
Good idea. It plugged up pretty quick.Voxster1965 wrote:Get your hands on some talc for that tube my friend
I had a few other issues, the dashpot is way too heavy for this head, heat wire fell off!, swarf tube needed to be closer and the l.p.i. number was just a guess. I think i bottomed out on the lacquer too.
But, it worked!
which are you cutting with the Presto 8dg or the Westrex 2b?
- Voxster1965
If you bottomed out on the lacquer, you will have stuffed your diamond up - cut shallow to start or you will be spending up big on replacement styli.
Im using a webster. My 2b isn't back yetilium wrote:which are you cutting with the Presto 8dg or the Westrex 2b?
I gotta rethink my whole mount if i wanna run smaller heads, because the mods to the lathe for the westrex.
