Need flexis for embossing
luke13
Post: # 46443Unread post luke13
Mon Mar 20, 2017 5:04 am
hallo my friends, I'm looking for flexis or pvc or similar sheet to make flexis ( i have a cutter plotter and ca cut round pvc sheet). I have a vanrock / atom mono recorder machine and would like to try to make flexis with embossing process ( i find on the web presto style stylus to emboss). I also try to cut with diamond stylus, sound quality is very good, but too expensive stylus for the limited work life. I also try to emboss with presto stylus with a standard pvc sheet that I find ( made by Fellowes, are binding covers 0,3 mm thickness) without good results and presto stylus stop to emboss after only 3 records... I'm desperate.... If anyone have an idea how can I do/use to realize flexis with my mono machine are very welcome!!!
Thanks in advance.
The Shank
Re: Need flexis for embossing
Post: # 46447Unread post The Shank
Mon Mar 20, 2017 10:47 am
luke13 wrote:hallo my friends, I'm looking for flexis or pvc or similar sheet to make flexis ( i have a cutter plotter and ca cut round pvc sheet). I have a vanrock / atom mono recorder machine and would like to try to make flexis with embossing process ( i find on the web presto style stylus to emboss). I also try to cut with diamond stylus, sound quality is very good, but too expensive stylus for the limited work life. I also try to emboss with presto stylus with a standard pvc sheet that I find ( made by Fellowes, are binding covers 0,3 mm thickness) without good results and presto stylus stop to emboss after only 3 records... I'm desperate.... If anyone have an idea how can I do/use to realize flexis with my mono machine are very welcome!!!
Thanks in advance.
http://www.myshank.com/en/transparent-blank/94-7-transparent-15mm-small-hole.html?search_query=flexi&results=1
Diamond can cut everything.... Absolutely everything... but not necessarily for a long time.
skype : steven.myshank
* Resharpening services
* Blank records
* Cutting lathe
