Preparing Pre-Masters for cutting..
descent
Post: # 46332Unread post descent
Mon Mar 06, 2017 7:21 pm
Hello brothers and sisters!
Many tests by my side, just to find a solution for cutting without big changes comparing with the original audio source.
Many problem everytime with middle frequences, a lot of distortion on human vocals or on middle range instruments (like guitar) :!:
What's your conclusion?
Re: Preparing Pre-Masters for cutting..
Post: # 46341Unread post Aussie0zborn
Mon Mar 06, 2017 10:54 pm
How long is a piece of string??
How about letting us know.....
Which cutting system? Cutterhead? Source Files? Blank Discs?
descent
Post: # 46345Unread post descent
Tue Mar 07, 2017 8:38 am
here we are:
Lathe cut machine: T560
Myshank or vinylrecorder blanks
I drive the music from my laptop.
concretecowboy71
Post: # 46405Unread post concretecowboy71
Mon Mar 13, 2017 3:03 pm
You may be overloading the head and causing it to resonate. Use EQ to get rid of the problem. Lower the level until the problem goes away. Then raise level until it comes back and use the EQ to tame the bad frequencies and raise the level a bit.
