Hi guys,
First off, if you pm me I will ignore you to the ends of the earth.
NO PM'S
If you can't say it here, then don't say it.
What is a Rek-o-cut imperial with 4 feedscrews, extra cutter needles and all the accessories worth?
(accesories not pictured but believe me, the rek-o-cut is loaded)
Apparantly this lathe has cut less than 35 records during it's life.
What should I pay considering that it works or is in need of very little?
A fair price from one forum member to another?
Tone arm and needle.....
tone arm is 16 inch I believe?
Rekocut Imperial with alllll the accesorie, An honest price?
Re: Rekocut Imperial with alllll the accesorie, An honest pr
I should probably mention that this lathe has cut about 35 records during it's life span,
low mileage original if you will...
