RCA MI-12701 78 Only Cutter - capstan dimensions?
piaptk
Post: # 44123Unread post piaptk
Mon Sep 26, 2016 11:31 pm
Hey everyone,
I bought a 78 onoy RCA cutter, but the rubber capstan was terribly warped (it's almost square!), and was wondering if anyone had one of these machines with a good one that could get me measurements of the capstan diameter.
sameal
Re: RCA MI-12701 78 Only Cutter - capstan dimensions?
Post: # 44128Unread post sameal
Tue Sep 27, 2016 9:21 am
Terry of terry's rubber rollers "may" have the original dimensions.
I say may because that's probably not something he see's everyday. But it's worth a try
Bahndahn
Post: # 44140Unread post Bahndahn
Tue Sep 27, 2016 11:32 pm
You may calculate it if you know the RPM of the motor, which may be listed on the motor or via the motor data sheet.
PullyRatio = RPMRoller ÷ RPMPlatter = DiameterPlatter ÷ DiameterRoller
Punch in what you have [platter diameter, desired platter speed, and roller speed] and simplify to obtain the diameter of the roller.
Bahndahn
Post: # 44141Unread post Bahndahn
Tue Sep 27, 2016 11:39 pm
In other words you can use the calculations found on the following link, just note that the only difference between a belt drive/pulley system and a direct contact roller system is that the direction of rotation is opposing for the two diameters in the latter.
http://www.cousesteel.com/AndysPlace/Pulleys.html
Post: # 44146Unread post markrob
Wed Sep 28, 2016 9:32 am
I don't know the RCA lathe, but if its done like the the Presto 6N, the roller in question is a idler and does not influence the platter speed. In that case, the diameter is not so critical as long as it allows the power to be transmitted to the platter from the motor.
piaptk
Post: # 44148Unread post piaptk
Wed Sep 28, 2016 10:10 am
This is an actual rubber capstan that directly turns the rim, so it definitely affects the speed.
Bahndahn, thanks for the formula!
