Dear Lathe trolls,
I have a Presto 6N I used to use years ago as my first system (with Grampian head). Im now setting it up with a technics SP10 turntable and am having a plinth made.
Anyone have some kind of template that shows the distance the hole should be from the turntable spindle?
I could measure it all out but, it would save the hassle if someone already has or has a piece of paper.
Cheers, Lewis
Presto 6N mounting template
- Cutterwoller
Re: Presto 6N mounting template
Only just saw your post - do you still need the measurements?
- Cutterwoller
I have now made the plinth and measured it the old fashioned way but, it would be nice to see what you your measurements are compared to mine. I think from central pin to pivot was 11 1/2''.
L
L
Mine measures about 29cm - looks like you've got it covered. Cheers!
