Help with New Lathe
Help with New Lathe
Hi Guys
I'm looking for help with my lathe, hoping its something simple I've missed.
I can help from the person that sold me the lathe but he's mega busy so any advice would be excellent
I can hear the track via the head and touching the stylus with a screwdriver I can feel the vibration, however all I seem to produce is noise, it actually sounds as if its recording the sound of itself cutting the disc, I don't have a microscope, just wonder if it's a heat issue etc, I don't have much heat on the disc at the moment and I'm testing with a dub plate
Re: Help with New Lathe
Could be the cutting needle?
Is it fresh and installed probably?
Is yr head positioned correctly?
weight/depth correct etc.?
sounds like it could be these...
cheers
cheers
Cheers,
recordboy
recordboy
Turned up the volume and added a weight to the head, something playing back
Still mushed up and too bassy
- Stevie342000
Has inverse RIAA been applied?Boydie wrote:Turned up the volume and added a weight to the head, something playing back
is it an old cutter? Decayed or damaged damping material? I don't actually know what the results would be if damping material was damaged, but it's something to check out.
I think it might be the head, I'll make a video to show you
