Presto K8 Lathe Arm
- tapesandtubes
Re: Presto K8 Lathe Arm
I think you have to unscrew the knurled knob and then loosen the hex nut at the base.
- tapesandtubes
Thanks, I got it figured out. You have to remove the hex screw that's on the knob and work that off (which was a pita) and the rest comes apart. Years of old grease sort of stuck everything together horribly...
Presto K8 | 6N
You can put a washer in there to raise the assembly in case you have a fancy tt mat. I took my mat off because my blanks were riding too high. I don't lean back too hard. We need a whole forum section for just the presto k series.
- tapesandtubes
Yeah, that's not a bad idea. I think there's enough people out there restoring these...
Presto K8 | 6N
- Jesus H Chrysler
loosen the allen head set screw on the cap and remove the cap. Then loosen the two on the gear arm. Then it should pull straight up. It may be a little rusty so you might have to work it back and forth as you pull, but that's all there is to it.
- grooveguy
That is a gorgeous K8; looks to be in pristine condition. Where on Earth did you find it? Has the advance ball, too. Wow! Is the rubber tire in good condition? What does one do if it isn't?
If one is need of rubber roller repair, it is essential to visit the expert on rubber roller repairs. One must contact this fellow:grooveguy wrote:That is a gorgeous K8; looks to be in pristine condition. Where on Earth did you find it? Has the advance ball, too. Wow! Is the rubber tire in good condition? What does one do if it isn't?
http://www.terrysrubberrollers.com/
