Russia brands lathes or cutting heads ?
Hello people, question of day : there were a or more brands of lathes or cutting heads originally produced in Russia in last 40 years ? Copy of Neumann or other ?
Isn't possible that in this world exist only Neumann, Scully, Lyrec and other for lathes, and for cutting heads Neumann, Westrex, Grampian, now too Vinylium and then Caruso, etc.; I don't believe that this is possible; for me there will be too some brands from Russia..., but which ?
- DaveRichter
Re: Russia brands lathes or cutting heads ?
wanna know that too
Perhaps uvoscillator that live to St. Petersburg could know these brands, if exist...
In the meantime , here a photo of a unknown russian cutting lathe
there are no professional russian lathes.
russia (melodia) had neumann lathes from the 60ies on. later a couple of dmm lathes.got records of that.
also all other east block countries used state of the art technology. neumann's... toolex alphas.
the market was just too small to develop an own lathe.
i guess space programm and atomic bombs kept them busy.
the one on the picture is prob. pre WW2 or shortly after.
Update : I have spoken with uvoscillator, and he confirm to me that all lathes in Russia were imported from Europe or other parts of world.
Perhaps there was a little production for military world.
Here some photos of a diy russian lathe :
great find! hehe.
do you have some high res pictures?
if you have it would be great to send me by mail...
and source where the lathes have been?
- uvoscillator
this double monster located in south of russia, own by my friend, one deck still works...
btw likey offtop, but interesting machine - magnetic disc turntable МАГ-Д1 (MAG-D1).
was made especially for military use, like fast recording and reproducing of Morse code messages...
ps I'll try ask someone about recorders, as in 60-70s recording flexis it was popular service like "sound letter"
Best !
- uvoscillator
sales now somewhere on south of russia
http://www.avito.ru/krasnodar/audio_i_video/vinilovyy_rekorder_289554985
Best !
Hmm, interesting lathe ... I have already seen this overhead somewhere...
European brand or other ?
- uvoscillator
I think it may be russian, but not sure, just an idea
Best !
- dubcutter89
looks like a neumann r21 / telefunken ela103 copy...
the cutterhead looks interesting
Lukas
Lukas
In the post by Sturiorp on the lathe there is a writing that translated in:
Construction by radio-hobbyist
Apparatus for sound recording on "bones" (X-ray film)
Radio-hobbyist - mechanic is unknown
Given to museum by Suchoverhovym E.V.
as i know during that time they recorded music on "bones" from tapes that were illegally recorded music from European radios.
_______
about the music on bones here are some great vids on youtube
https://www.youtube.com/watch?v=49aWAHqi200
https://www.youtube.com/watch?v=XMCCYnDvpJQ
Flo, Melodia was also using Ortofon/Lyrec systems, I have some articles with pictures somewhere. I have actually not seen any pictures of them using Neumann lathes, but they probably did.
I'm sure there were manufacturers of lathes in Russia, probably pre-war. Almost every country had some kind of lathe manufacturer prior to the invention of tape recording. Were any of these professional lathes? Well, I think the popular distinction between pro and not-pro lathes is fundamentally flawed, since "professional" is supposed to mean anything that was used as part of conducting business. In this sense, I am pretty sure all the Prestos, RekOkuts Fairchilds, etc. certainly count as professional lathes of their time, since very few people back then were rich enough to have one simply as a hobby. Most of these were being used professionally.
The Neumann and Scully systems however reached such a high level of sophistication that it is undeniably faster and easier to achieve professional results by todays standards on these rather than on anything else. This is not to say that you should not attempt to cut masters or dubplates on anything else, it simply means that anything else will be far less comfortable to use and it will probably take a lot longer to get similar results. You also run the risk of never getting adequate results if you are using an ancient system. In this sense, not so good for business.
Most of the pre-war lathes were not as quiet and precise as the Neumann and Scully lathes, but they can of course be modified, if you are wiling to spend the time and money. The only catch is that there is no real support for anything you do to customize an older system and you are completely on your own with it. It might work if you are skilled enough, and it might also not work. With a Neumann system, you have better chances of it performing to a standard that can be used to cut commercial masters nowadays, and even if you cannot achieve this on your own there are at least a few people in the world with enough experience to get the job done in repairing your Neumann lathe.
On the other hand I have personally succeeded in getting an ancient Fairchild lathe to perform to professional standards of sound quality, and I know of at least a couple of more cases including a Presto 8DG and other such systems that have successfully been used to cut professional masters in the past decade. However, by the time you get there it is questionable whether the whole process will have come out any cheaper than buying a Neumann lathe to begin with and the result may not be as ergonomic as a Neumann system, or worse, not achieving the same standards of performance. As a general rule of thumb, anything that will achieve the same standards of performance of a Neumann lathe will cost as much or more than a Neumann lathe.
I have been documenting lathe manufacturers and models by country, and I am slowly trying to compile a complete list. 99% of these will never be able to achieve decent sound quality by todays standards, but then there is always the 1% and your potentially innovative ideas...
Whether what you end up with can viably be used as part of conducting business or not, nobody can predict. I have even seen some Neumann and Scully lathes in such extreme stages of decay, that they do not really stand much of a chance of being put to commercial use. The brand itself is by no means a guarantee. A sturdy lathe base of potentially Russian manufacture (if you can find something like that) may have better chances of success than a completely worn out Neumann system. So keep on searching and keep us up to date with your findings.
thanks for info.
I had an old magazine that was monthly printed about newest things in technology and stuff during soviet times. there was a article about vinyl cutting. I will try to find, scan it and maybe if have time to translate...
best regards.
best regards.
_______
- untitledthe
Nice read this topic, sorry for bringing it up again
