okay i posted awhile ago about my meissner model 9-1065 cutting with high end surface noise before and after on and off months fiddling with it, i have determined that the left channel cuts decent enough and the right channel is the surface noise. this is a mono cutter so im assuming it is vibrating in such a way to cause a right track to form that isnt from the music.
is there any way to eliminate this right channel noise?
cutter cuts with surface noise
