audax rh5 diy repair assistance?
petermontg
Post: # 16749Unread post petermontg
Mon Oct 17, 2011 9:58 am
d wrote:
p.s. when the coil burned it fired up the coil holder, so i had to do it from the scratch. took a sheet of glass textolite 0.2mm i think and with epoxy glues the holder.
Thanks d,
ill try and hunt some down and build the replacement.
thanks again
Peter Montgomery
+353(0)894926271
d
Post: # 16754Unread post d
Mon Oct 17, 2011 1:23 pm
of course i could make some pictures but i do not thing it would be any good for you. I did not a good job. but it works. when i got another cutter i just put audax aside. two things to mention is that you have replace rubber damping with some sort of rubber. when I tried silicon rubber of 1mm it seamed like it is not very firm as the high frequency went down at about 7-8 khz. when i took shrinkable isolation and made two layers on each side of damper where the rubber must go it got better. but then I stoped testing it. so that would be the start. maybe someone here can help you on that more.
anyway is is not a very big deal to fix that head.... i think ;)
_______
