list of heating components
I need a list of heating components to heat my stylii
can someone assist me?
40 gauge NiChrome wire. Wrap the stylus a number of turns with the wire. Use Dental Cement to keep it in place.
The wires are then connected to a DC power supply. A variable resistor (potentiometer) is used to adjust current flow. You could add a meter so you can adjust current to a specific point that you know gives you good heat.
Be careful. Too much heat will bake the chip coming off the lacquer to the stylus. If this happens the stylus is done.
