no sound from groove.
emidisc
Post: # 14888Unread post emidisc
Sat May 14, 2011 6:47 pm
I recently read a posting regarding a troll cutting but getting no sound
on playback
I am using new saphire and I am getting sound at the cutter head
and can feel vibration at the stylus but only background noise on
playback I have tried adjusting depth of cut and stylus angle, probably something obvious - sure I read someone on this forum with similar problem just cant locate it
any help appreciated
emidisc
d
Post: # 14892Unread post d
Sun May 15, 2011 3:36 am
Maybe recorded sound is too low? What cutter are you using? Maybe you applying too much pressure on the head while cutting?
SueDenim
Post: # 14893Unread post SueDenim
Sun May 15, 2011 5:26 am
Just to confirm, are you cutting or 'embossing'?
If cutting, what does the chip look like? (eg. is it grey/shiny, thick/thin etc.)
emidisc
Post: # 14898Unread post emidisc
Sun May 15, 2011 8:37 am
I am cutting getting good continuous thread
d
Post: # 14899Unread post d
Sun May 15, 2011 8:56 am
maybe stylus is badly secured in place? What cutter do you have?
emidisc
Post: # 14903Unread post emidisc
Sun May 15, 2011 9:15 am
I have a Birmingham Sound Reproducer BSR 33C
pretty sure stylus is secure...........
d
Post: # 14905Unread post d
Sun May 15, 2011 9:29 am
hmmm... I don't know this cutter. I had a similar thing with Audax h4. When it came I got sound from it and thought everything is ok. But when cutting I got very low sound.
I took apart and saw that rubbers used as dampers where worn out or got exhausted through time. Then I changes to what I had on hand - and that was 1mm silicon technical rubber. Worked better after all.
Maybe you have the same problem?
andybee
Post: # 14908Unread post andybee
Sun May 15, 2011 9:44 am
mabe stylus is mounted 180degrees wrong.
d
Post: # 14910Unread post d
Sun May 15, 2011 10:47 am
Then it would emboss not cut. As Emidisc stated he is getting a good swarf... And even if embossing there should be ANY reflection of sound.... :)
Emidisc what material are you cutting on?
D
