diamond stylus for grampian b/d
- dietrich10
picked up an RCA lathe with gotham+grampian combo. plan to do some lexan or similar cuts. anyone create way for mount diamonds etc?
D
D
cutting lacquers-vms70 system
- TotalSonic
I'm not using one yet, I'm still trying to decide if I should invest in a stylus, or buy a box of 50 acetates..
Poly is waaaay cheaper, but i have a bunch of sapphires that are good..
so either way, it would cost me about the same amount.. $400 for a stylus, or a box of dubs.
box of dubs I know how to cut already, and I know they sound good..
diamond styli could be damaged very quickly if I'm not careful, but the material is about 90% cheaper then acetates (found a great supply for about $1.50 per 10" if i cut the circles myself)
now since I never heard a poly cut, I don't know how they compare. From my tests with the white sapphire, I think they COULD sound just as good, and they would last as long as vinyl theoretically..
with my up and coming tour quickly approaching, I think I'm going to have to bite the bullet and get the dubs, since I heard shank takes up to 3 weeks for shipment on styli.
really wanted to cut my set on poly, so I'd only need one copy of each record to get through the tour. If I use acetate, I'll have to cut doubles of everything, just in case..
so for me its a catch 22, with no right answer..
- dietrich10
I've cut about 12 records on mine so far and it's doing great. Everything from a minimal techno 12" for a friend of mine to some alternative stuff on 7" and some dub reggae 7" and some folk and metal, all resulting in great sounding cuts
all the best!
- tommie 'plan 9' emmi
