About "Vinyl Blanks"
Post: # 752Unread post Aussie0zborn
Thu Nov 23, 2006 5:06 pm
Can someone tell me what the story is with "vinyl blanks"??? As I understand it these are vinyl pressings that can be cut even on a professional lathe.
Does anybody use them and what do they sound like?
Internet
Re: About "Vinyl Blanks"
Post: # 753Unread post Internet
Thu Nov 23, 2006 6:34 pm
Aussie0zborn wrote:Can someone tell me what the story is with "vinyl blanks"??? As I understand it these are vinyl pressings that can be cut even on a professional lathe.
I already try to cut blank pressed vinyls. Result is not so good.
the biggest problem is the noise. the pressed vinyl is very hard to be cut with a stylus (diamond or nhs) PVC blank records are better.
the other problem is the life time of the record, shorter than PVC too.
One time, a cut was good (I mean no noise) and the sound is really better, bass frequency are really better. I have been cutting those records with a vinylrecorder. Maybe someone else here already tryed to cut with a professionnal cutter....
d
Post: # 754Unread post d
Fri Nov 24, 2006 5:46 am
hello,
As I understand vinyl record is not the same PVC, and it is better to be pressed. Somewhere I read about vinyl record material and PVC is polyvinylchloride.
There is some more questions on my mind:
is the material just black PVC? Does anyone do PVC blanks for yourself or buying from somewhere? ;)
The thing is that when buying PVC it goes in sheets. Question is how to do it perfectly round?
Thanks
Internet
Post: # 755Unread post Internet
Fri Nov 24, 2006 6:06 am
This is not just black PVC, there are so much sort of PVC...
On this PVC, there is a small mirror surface (very hard to find, only in germany I think).
d
Post: # 756Unread post d
Fri Nov 24, 2006 6:17 am
but its called PVC, or it has some kind of other description?
I went to local shop where those kinds of material are. There is some kind of PVC that I think would be good. Unfortunately they are out of stock, so i'm waiting when new package arrive and i'll try cut on them.
Internet
Post: # 757Unread post Internet
Fri Nov 24, 2006 8:18 am
I don't know for the name...
Maybe what you find could be good to cut...
Let us know.
d
Post: # 758Unread post d
Fri Nov 24, 2006 8:22 am
Of course i'll let you know! ;)
thomas
late
Post: # 859Unread post thomas
Mon Jan 01, 2007 10:45 pm
posted this elsewhere-
Four years ago I heard a blank that had been cut on a Scully. The impression, the cutter gave me when we talked, was the trade off was stylus wear not sound quality. Something like 75 cuts on lacquer compared to 7 on vinyl. The blank supplier was different, I vaguely recall the name 'Bamboo Guy'.
Aussie0zborn hey,
Between you me, the compound has to be the softest of the softest to be used for cutting, and then some. The dies would have to have no profile, so the cutterhead could track.
The system I had heard it on was not professional, so cannot speak for sound quality.
The guy handled the thing like it was glass, yet other records like tissue paper.
Post: # 861Unread post Aussie0zborn
Fri Jan 05, 2007 9:27 pm
Hey Thomas,
Welcome to the Lathe Trolls. Do you know where I can get records pressed in the New York area???
Cheers,
Aussie 0zborn
thomas
Post: # 862Unread post thomas
Sat Jan 06, 2007 10:03 pm
Hi Mikey,
Fancy meeting you here.
There are three plants in metro area, all in brooklyn. Just outside of metro area are two more, both jersey.
