T560 Overhead motor
Rochester
T560 Overhead motor
Post: # 64451Post Rochester
Mon Mar 25, 2024 1:03 pm
Does anyone have advice / instructions on the dis assembly of the overhead motor / worm drive for the T560? I'm having clutch issues and wondering whether to change the clutch bearing or just tighten the screw tighter. TIA.
Re: T560 Overhead motor
Post: # 64454Post tragwag
Mon Mar 25, 2024 3:14 pm
here's a great thread to get you started: https://www.lathetrolls.com/viewtopic.php?f=1&t=8894
Dub Studio
Post: # 64474Post Dub Studio
Fri Mar 29, 2024 8:04 am
What issues are you having?
Rochester
Post: # 64483Post Rochester
Mon Apr 01, 2024 2:27 am
I (stupidly) left the groove motor running unsupervised so it ran right to the end of its travel. Since then it seems to move less freely and I need to tighten the thumb screw more in order to stop it slipping. So I presume I have damaged the clutch bearing.
Dub Studio
Post: # 64704Post Dub Studio
Wed Apr 24, 2024 4:24 am
Hm, its quite common for that to happen, and it shouldn't damage the clutch. It's more likely to be an issue with the lead screw itself. When you wind it back, the screw has to lock back onto the nut, so perhaps its cross threaded, or there is some grit / swarf stuck in there. I would try running it to the end of its travel again and gently winding it back to lock it back on.
