T560 Overhead motor
T560 Overhead motor
Does anyone have advice / instructions on the dis assembly of the overhead motor / worm drive for the T560? I'm having clutch issues and wondering whether to change the clutch bearing or just tighten the screw tighter. TIA.
Re: T560 Overhead motor
here's a great thread to get you started: https://www.lathetrolls.com/viewtopic.php?f=1&t=8894
- Dub Studio
I (stupidly) left the groove motor running unsupervised so it ran right to the end of its travel. Since then it seems to move less freely and I need to tighten the thumb screw more in order to stop it slipping. So I presume I have damaged the clutch bearing.
- Dub Studio
Hm, its quite common for that to happen, and it shouldn't damage the clutch. It's more likely to be an issue with the lead screw itself. When you wind it back, the screw has to lock back onto the nut, so perhaps its cross threaded, or there is some grit / swarf stuck in there. I would try running it to the end of its travel again and gently winding it back to lock it back on.
