So your cutting level is ok? It just gets hot after a few minutes?
Maybe your amp is DC unstable and puts out a few Volts DC into the head which you cannot hear but will heat up the coil...
Maybe measure the output of your amp?
Lukas
Cutting Head gets really Hot
- dubcutter89
Re: Cutting Head gets really Hot
No, from all the symptoms your head is half cooked! You'll even find that your amp is using much more power than normal due to the lower resistance.
Get it wound!
Get it wound!
