Best Settings for Bayer Makrolon Discs
MightyRecords
Post: # 39499Unread post MightyRecords
Thu Jan 07, 2016 1:38 pm
Hello Trolls!
I am a VR T560 user, and I recently got transparent 12" discs cut using 2mm Bayer Makrolon GP. I am getting a high amount of surface noise, even with a new stylus. I have tried different weights, blank heating, and stylus heating, but still cannot cut a quiet groove. I was wondering if anyone with a similair set-up had any suggestions? What weight and heats do you use?
Thanks in advance, any help would be greatly appreciated.
Cheers,
Andrew
studiorp
Re: Best Settings for Bayer Makrolon Discs
Post: # 39501Unread post studiorp
Thu Jan 07, 2016 2:19 pm
For reduce the noise during cutting process, I use on polycarbonate before to start to cut wood spray with beeswax. Try !
SUNBEARS
Post: # 39503Unread post SUNBEARS
Thu Jan 07, 2016 3:30 pm
Honestly, just don't worry yourself with trying to make your own blanks. It's not cost effective enough! - Aside from that, The Shank has as superior blank. Vouching hard for him here. Truly, longest stylus life and quietest groove with minimal heat.
That being said, if you're going to stick with PC, I would check out opcode66's Plastic Cutting Guide. Follow it to a T and you should get great results.
https://www.youtube.com/watch?v=1dGU79-1DYM
Make sure the bottom of your cutterhead is perpendicular to the surface of the blank.
Cheers,
J
SUNBEARS
Post: # 39541Unread post SUNBEARS
Fri Jan 08, 2016 1:12 pm
And by perpendicular, I actually mean the exact opposite. Wow, sorry about that. Bottom of the cutterhead should be PARALLEL to the surface of the disc. Oof.
Cheers,
J
studiorp
Post: # 39546Unread post studiorp
Fri Jan 08, 2016 3:03 pm
Check too the cutting pressure and angle of cut.
MightyRecords
Post: # 39547Unread post MightyRecords
Fri Jan 08, 2016 3:15 pm
Thanks so much for your responses.
SUNBEARS when you say "Bottom of the cutterhead should be PARALLEL", are you talking about the diamond stylus or the metal cutterhead?
Should the stylus be positioned like A or B in this drawing?
Studiorp, what pressure (weight) do you use for plastic?
I really appreciate the help.
Cheers,
Andrew
studiorp
Post: # 39551Unread post studiorp
Fri Jan 08, 2016 5:46 pm
Hi, the figure A is right; you must see the reflection of your cutting stylus on surface disk; your stylus must be vertical than disk, near 90 degrees.
About the weight of cutting pressure, this depend from head that you have; don't exist a value for all heads. when you start to cut on disk, you must "hear" a silent groove, but in the same time it must be deep, otherwise you will have tracking problems, so don't exagerate with pressure. For do this adjustment, better use a tonearm while cut on disk.
sat159p1
Post: # 39712Unread post sat159p1
Thu Jan 14, 2016 9:34 am
studiorp wrote:Hi, the figure A is right; you must see the reflection of your cutting stylus on surface disk; your stylus must be vertical than disk, near 90 degrees.
My figure is towrds "B" than "A" or something maybe ideal in between. Of course when cutterhead is flat 180* to the disc. The slot for stylus in VRS is not 90* to the disc, and the stylus bought from myshank and souris are different heights so they can't be ideal 90* to the surface. Every time I set this is slightly different but never like "A" - pic below form today cutting session.
ilovethelawrencearms
Post: # 43513Unread post ilovethelawrencearms
Wed Aug 10, 2016 8:59 am
So do some of you cut at close to 90 degrees with Makrolon? I have been having similar issues with surface noise, cant seem to pinpoint what is going on. Everything was working great before.
