10" lathe cuts.
- uncle muddy
10" lathe cuts.
I had posted a request, but quickly realized I'd titled it poorly (and most likely in the wrong area)... so, I'll put myself at the mercy of the court.
Looking to have some 10" lathe cut records done...
Length is aprox. 12-15 mins a side.
Is anyone cutting in stereo, or is it all mono?
Minimum order?
Pricing??
I've seen some cuts done on black vs. clear... is there a sound benefit to the black?
(or even less of a dust magnet??)
Feel free to reply here or pm me...
thanks again.
Minimum order?
Pricing??
thanks again.
Re: 10" lathe cuts.
i can do some 10" lathe cuts for you.
mine are mono, on clear.
those cuts you've seen on black are the same exact material, no noticeable sonic difference.
check out my site:
www.audiogeography.com/records.htm
check out my site:
Re: 10" lathe cuts.
Black discs are simply two clear layers glued together with a black sheet in the middle. What Tyler said is dead on correct. They have the appearance of being black, but what you are cutting into is actually clear plastic (which does give the best sound).
- uncle muddy
Re: 10" lathe cuts.
Thanks, I was curious about that.
While I enjoy the look of the clear vinyl, I had seen some black lathe cuts, and had wondered about that.
