Advice for upgrading my amp/cutter head
I use a presto 6n machine.
Im currently using the cutting head and amp from a presto K8.
I have a presto 1-D head (500ohm) that im unsure if its in working condition...
I also have a tube Gates power amp that was manufactured for driving cutting heads (came with the set up/1-D head) which I know needs work. Its freaking huge and heavy.
I wanna get my Presto 1-D head operational since these are pretty solid heads/
What the heck should I do? ? ? ?
Is there any way to test my 1-D head to see if its working without sending audio thru it? This head is a feedback head, yes?
You may want to contact Bruce Leslie at Pro Recording (216)662-1435. This guy is an encyclopedia for presto stuff and is currently rebuilding my 1-C head. He can rewind them for something besides 500 ohm, such at 16 or 8 ohm so you can use any old power amp you want. He will also replace the damping material and get it back up to spec (or better in the case of my 1-C). He has very reasonable rates. I'd suggest calling him.
As far as I know, I thought the 1-D was a NON-feedback head.
-aaron
-aaron
- Steve E.
- Site Admin
I recommend hallucinogenic cactus, but only under the supervision of a mature, trained elder in the Native American tradition.JayDC wrote:I would like to get my head rewound..
(This forum does not necessarily represent the views of this forum, and we make no claims as to the wisdom or legality of our "advice.")
All I have to say to that is: The next time your in amsterdam, don't eat the hawian mushrooms. They look small and dinky, but don't let fool yah.. You'll lose your mind.Steve E. wrote:I recommend hallucinogenic cactus, but only under the supervision of a mature, trained elder in the Native American tradition.
